查看: 6139|回复: 2
请教有关Fluent的问题
发表于 2009-8-10 20:01:12 | 显示全部楼层 |阅读模式
我在使用Solve--->Controls--->Solution命令时,遇到如下错误提示:
Warning: It appears that symmetry zone 3 should actually be an axis
         (it has faces with zero area projections).
         Unless you change the zone type from symmetry to axis,
         you may not be able to continue the solution without
         encountering floating point errors.
这是怎么回事?
而且在迭代时,又出现如下错误提示:
iter continuity x-velocity y-velocity          k    epsilon   vf-vapor     time/iter
Interrupting...
     1 0.0000e+00 8.7272e-05 0.0000e+00 0.0000e+00 3.0939e+02 0.0000e+00  0:00:00  999
Done.
     1 0.0000e+00 8.7272e-05 0.0000e+00 0.0000e+00 3.0939e+02 0.0000e+00  0:00:00 1000
reversed flow in 12 faces on pressure-outlet 5.
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 17 cells
     2 1.0000e+00 1.4712e+00 3.0292e-03 2.0781e+01 1.2491e+07 0.0000e+00  0:00:00  999
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1551 cells
Error: Floating point error: invalid number
Error Object: ()
Error Object: ()
     3 1.0000e+00 1.2312e+00 1.1388e-01 8.0022e+04 1.#INFe+00 0.0000e+00  0:00:00 1000
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1589 cells
     4 1.3314e-01 5.4748e-01 1.1244e-01 8.8883e-01 1.#INFe+00 0.0000e+00  0:00:00  999
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 409 cells
     5 1.0000e+00 1.9118e-01 5.1680e-02 2.7826e-01 1.0691e+10 1.2033e-01  0:00:00  998
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1249 cells
     6 5.5605e+02 4.5331e-01 5.5060e-01 3.0288e+00 1.#INFe+00 2.3507e-01  0:00:00  997
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1538 cells
     7 1.4592e+04 2.2429e-01 2.5064e-01 1.3292e+02 1.#INFe+00 2.7127e-01  0:16:36  996
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1554 cells
     8 1.1342e+05 6.7270e-01 6.3969e-01 8.0000e-01 1.#INFe+00 2.9570e-01  0:13:16  995
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1592 cells
Error Object: ()
这又是怎么搞的?
发表于 2010-4-6 11:17:37 | 显示全部楼层
Define-》Boundary Conditions  试试将symmetry设为axis,看行不行
发表于 2011-9-14 10:48:59 | 显示全部楼层
我也碰到同样的问题了 边界条件设为axis也不行。
哪位高手给指点指点啊
