查看: 3010|回复: 1
请教Tecplot问题
发表于 2009-8-11 20:28:29 | 显示全部楼层 |阅读模式
用Tecplot导入文件时,有如下出错提示:Aspect  ratio  exceeds  ratio  limit. The  ratio has been adjusted.
单击确定后,又有如下提示:Axis  Mode  has  been  reset  to  be  " Independent ",单击确定后,屏幕显示:Restricted  Tecplot : Not  a  allowed  to  display  this  data  set.
请教这是怎回事?
发表于 2009-8-13 17:10:52 | 显示全部楼层
只要导入没问题就好了,再调整XYZ范围
