查看: 3458|回复: 1
cfx怎样设置钢水的凝固潜热
发表于 2009-8-26 14:24:59 | 显示全部楼层 |阅读模式
这个错误提示是什么意思啊?
Wall Heat Transfer Coefficient written to the results file uses    |
| "Wall Adjacent Temperature" for the bulk temperature.  If you want |
| to override the bulk temperature then set the expert parameter     |
| "tbulk for heat tran coef = <value>"
发表于 2014-1-14 15:59:31 | 显示全部楼层
需要设置热交换系数
