查看: 5181|回复: 5
FLUENT双核时导入GAMBIT网格出现问题,求助
发表于 2009-9-23 11:21:52 | 显示全部楼层 |阅读模式
FLUENT启动双核后,显示
ID     Comm.   Hostname        O.S.        PID     Mach ID HW ID   Name
host   net     PC-200902281512 Windows-32  2496    0       1756    Fluent Host
n1     mpich2  PC-200902281512 Windows-32  852     0       1       Fluent Node
n0*    mpich2  PC-200902281512 Windows-32  1616    0       0       Fluent Node
表示双核启动成功
但在导入GAMBIT绘制的网格后,显示出现如下问题:
Reading "D:\missle.msh"...
  203721 nodes.
   35401 mixed wall faces, zone  3.
    5494 mixed pressure-far-field faces, zone  4.
   94777 mixed symmetry faces, zone  5.
1953190 mixed interior faces, zone  7.
1010513 tetrahedral cells, zone  2.
Parallel variables...
Building...
     grid,
        auto partitioning mesh by Principal Axes,
        distributing mesh
                parts..,
                faces..,
      default-interior -> default-interior (7) and default-interior:006 (6)
      default-interior -> default-interior (7) and default-interior:008 (8)
Note: Separating interior zone 7 into zones 7 and 6.
Note: Separating interior zone 7 into zones 7 and 8. unable to read the cmd header on the pmi context, Undefined dynamic error code.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
job aborted:
rank: node: exit code[: error message]
0: PC-200902281512: 123
1: PC-200902281512: -1073741819: process 1 exited without calling finalize
The Parallel FLUENT process could not be started.
 楼主| 发表于 2009-9-23 11:25:07 | 显示全部楼层
回复 1# njustfluid 的帖子
导入的网格文件是教材光盘自带的,没启动双核时CHECK过,是没问题的,而且在教研室另一台四核的机器上也试过,也没问题。实在搞不懂为什么会这样?哪位高手能指点一下?急盼
发表于 2009-9-25 11:16:43 | 显示全部楼层
恩,怎么回事?我也是的,那位侠解释下
发表于 2009-9-28 10:00:58 | 显示全部楼层
我一般是在连续求解器里设好所有条件,并分割好网格,然后输出case,再用并行求解器读入case,初始化,计算。有一点很重要:在连续求解器里千万不要初始化,不然就不行了。
你可以试试。如果还不行联系我:lian3714@163.com
发表于 2009-9-28 10:01:43 | 显示全部楼层
我也曾经试过直接用并行求解器读入mesh,出现了你这样的错误
发表于 2009-9-28 10:39:17 | 显示全部楼层
弱问一下,一般FLUENT求解器就是连续求解器吧
