查看: 4075|回复: 1
十万火急,请教大虾们一个问题
发表于 2009-9-29 10:58:34 | 显示全部楼层 |阅读模式
我用gambit建立的模型,划分好网格之后输出case文件,fluent读入时出现以下提示,哪位可以帮我看一下这些错误怎么解决?
Loading "C:\Fluent.Inc\fluent6.2.16\lib\fl114.dmp"
Done.
Warning: -path flag not specified. Defaulting to -pathC:\Fluent.Inc
     Welcome to Fluent 6.2.16
     Copyright 2005 Fluent Inc.
     All Rights Reserved
Loading "C:\Fluent.Inc\fluent6.2.16\lib\flprim1119.dmp"
Done.
Host spawning Node 0 on machine "z-f63303c918d44" (ntx86).
ID     Comm.   Hostname        O.S.        PID     Mach ID HW ID   Name
host   net     z-f63303c918d44 Windows-32  2460    0       1836    Fluent Host
n1     smpi    z-f63303c918d44 Windows-32  3088    0       1       Fluent Node
n0*    smpi    z-f63303c918d44 Windows-32  3688    0       0       Fluent Node
Kill script file is C:\\Fluent.Inc\\ntbin\\ntx86\\kill-fluent-z-f63303c918d44-4032.bat
> Reading "F:\Xiaonan's keti\xiugai-wangge.msh"...
1293954 nodes.
   83110 mixed wall faces, zone  4.
     180 mixed pressure-outlet faces, zone  5.
   45292 mixed wall faces, zone  6.
     960 mixed interior faces, zone  7.
     144 mixed outflow faces, zone  8.
      96 mixed velocity-inlet faces, zone  9.
     100 mixed pressure-outlet faces, zone 10.
   11306 mixed wall faces, zone 11.
Warning: Reversing 96 faces, zone 11.
   16663 mixed wall faces, zone 12.
   53819 mixed wall faces, zone 13.
   21377 mixed wall faces, zone 14.
      16 mixed interior faces, zone 15.
Warning: Reversing 8 faces, zone 15.
      16 mixed interior faces, zone 16.
     418 mixed velocity-inlet faces, zone 17.
     330 mixed velocity-inlet faces, zone 18.
     418 mixed velocity-inlet faces, zone 19.
     418 mixed velocity-inlet faces, zone 20.
     660 mixed wall faces, zone 21.
    2746 mixed wall faces, zone 22.
     624 mixed wall faces, zone 23.
    2871 mixed wall faces, zone 24.
   17294 mixed wall faces, zone 25.
   19445 mixed wall faces, zone 26.
    6410 mixed wall faces, zone 27.
   21456 mixed wall faces, zone 28.
     674 mixed interior faces, zone 29.
     564 mixed interior faces, zone 30.
     670 mixed interior faces, zone 31.
     492 mixed interior faces, zone 32.
    4459 mixed wall faces, zone 33.
     100 mixed pressure-outlet faces, zone 34.
     100 mixed pressure-outlet faces, zone 35.
     100 mixed pressure-outlet faces, zone 36.
     376 mixed interior faces, zone 37.
     376 mixed interior faces, zone 38.
3739334 mixed interior faces, zone 40.
  701357 mixed cells, zone  2.
  697791 mixed cells, zone  3.
Parallel variables...
Building...
     grid,
        auto partitioning mesh by Principal Axes,
        distributing mesh
                parts..,
                faces..,
Note: Separating wall zone 4 into zones 4 and 39.
      wall -> wall (4) and wall:039 (39)
Note: Separating wall zone 6 into zones 6 and 41.
      guidibimian -> guidibimian (6) and guidibimian:041 (41)
Note: Separating wall zone 11 into zones 11 and 42.
      pbm -> pbm (11) and pbm:042 (42)
Note: Separating wall zone 13 into zones 13 and 43.
      suidao-bimian -> suidao-bimian (13) and suidao-bimian:043 (43)
Note: Separating wall zone 14 into zones 14 and 44.
      suidao-diban -> suidao-diban (14) and suidao-diban:044 (44)
Note: Separating wall zone 24 into zones 24 and 45.
      zhantai-zhichengzhu -> zhantai-zhichengzhu (24) and zhantai-zhichengzhu:045 (45)
Note: Separating wall zone 25 into zones 25 and 46.
      zhantai-dingban -> zhantai-dingban (25) and zhantai-dingban:046 (46)
Note: Separating wall zone 26 into zones 26 and 47.
      zhantai-diban -> zhantai-diban (26) and zhantai-diban:047 (47)
Note: Separating wall zone 28 into zones 28 and 48.
      churukoubi -> churukoubi (28) and churukoubi:048 (48)
Note: Separating interior zone 40 into zones 40 and 49.
      default-interior -> default-interior (40) and default-interior:049 (49)
Note: Separating interior zone 40 into zones 40 and 50.
      default-interior -> default-interior (40) and default-interior:050 (50)
Note: Separating wall zone 4 into zones 4 and 51.
      wall -> wall (4) and wall:051 (51)
Note: Separating wall zone 11 into zones 11 and 52.
      pbm -> pbm (11) and pbm:052 (52)
Note: Separating wall zone 11 into zones 11 and 53.
      pbm -> pbm (11) and pbm:053 (53)
Note: Separating wall zone 13 into zones 13 and 54.
      suidao-bimian -> suidao-bimian (13) and suidao-bimian:054 (54)
Note: Separating wall zone 26 into zones 26 and 55.
      zhantai-diban -> zhantai-diban (26) and zhantai-diban:055 (55)
Note: Separating interior zone 40 into zones 40 and 56.
      default-interior -> default-interior (40) and default-interior:056 (56)
                nodes..,
                cells..,
999999 (..\..\src\mpsystem.c@1228): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
Process [0] exited with status [-1073741819]
Process [1] exited with status [-1]
MPIRUN exited with status [0]
The Parallel FLUENT process could not be started.
我是在单核机上建模,双核机上计算...
发表于 2009-10-9 12:47:56 | 显示全部楼层
回复 1# hayijey 的帖子
先不用并行可以导入吗?
