查看: 8542|回复: 3
求助:单机多核带UDF并行计算fluent出错
发表于 2009-12-15 23:04:26 | 显示全部楼层 |阅读模式
interpreted UDF通过了,但是一开始计算就出现下述问题,是怎么回事?请指教!
unable to read the cmd header on the pmi context, Undefined dynamic error code.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
received suspend command for a pmi context that doesn't exist: unmatched id = 3
received suspend command for a pmi context that doesn't exist: unmatched id = 2
received suspend command for a pmi context that doesn't exist: unmatched id = 0
job aborted:
rank: node: exit code[: error message]
0: HUXUEQIN: -1073741819: process 0 exited without calling finalize
1: HUXUEQIN: -1073741819: process 1 exited without calling finalize
2: HUXUEQIN: -1073741819: process 2 exited without calling finalize
3: HUXUEQIN: -1073741819: process 3 exited without calling finalize
The Parallel FLUENT process could not be started.
发表于 2011-11-11 09:22:10 | 显示全部楼层
回复 3# windstar1985031 的帖子
告诉你一个方法,我今天刚解决的:
采用launcher启动并行处理器,将mesh或cas文件和udf(与串行无异)放进launcher文件夹里,读入mesh或cas文件,再compile UDF就可以了。。。
回复 支持 0 反对 1
使用道具 举报
发表于 2009-12-27 20:20:21 | 显示全部楼层
1.应该用编译的udf;
2.应该把cas和udf放在同一文件夹;
3.load时用绝对地址;
4.工作目录和安装目录设置共享
发表于 2010-1-21 09:47:56 | 显示全部楼层
回复 2# swimming02 的帖子
,按你说的做了,还是没成功呢。单机多核并行运算的udf怎么加载呀?编译没问题~~
