查看: 2833|回复: 0
CFX计算错误,各位大虾看看怎么回事?
发表于 2009-12-22 13:53:47 | 显示全部楼层 |阅读模式
计算出现错误,对结果看不大懂。希望高手指教。谢谢+--------------------------------------------------------------------+
|        Memory Allocated for Run  (Actual usage may be less)        |
  Data Type      Kwords  Words/Node  Words/Elem     Kbytes  Bytes/Node
  Real          64910.7      401.32       72.72   253557.2     1605.30
  Integer       28637.0      177.05       32.08   111863.4      708.22
  Character      2343.4       14.49        2.63     2288.4       14.49
  Logical          40.0        0.25        0.04      156.2        0.99
  Double          608.0        3.76        0.68     4750.0       30.07
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| ****** FATAL ERROR ****** The orthographic view transformation fa- |
| iled on domain interface "Interface 1".  Failure may be due to r=- |
| 0 included in transformed cylindrical coordinates of an interface  |
| with rotational relative motion.                                   |
| Stopped in routine SRF_ORT                                         |
|                An error has occurred in cfx5solve:                 |
| The CFX-5 solver exited with return code 1.   No results file has  |
| been created.                                                      |
End of solution stage.
This run of the CFX-5 Solver has finished.
