查看: 2292|回复: 1
【求助】gambit2.3的安装问题(之前安过exceed10)
发表于 2010-1-22 02:21:28 | 显示全部楼层 |阅读模式
安装过程中,安装到默认目录C:Fluent.Inc,将license.dat复制到C:Fluent.Inclicense
但是安装过程中有一个环节不知道是什么意思:
第一空电脑填了默认的数4位具体是什么记不清了
第二空电脑让我输入hostname我输入了计算机名
第三选路径我选C:Fluent.Inclicenselicense.dat
我觉得可能是这一步出了问题,希望有朋友能指正,不胜感激!
以下是完整的报错消息:
Locating Exceed installation ...
Launching Exceed 10 ...
Starting C:Fluent.Incgambit2.3.16ntx86gambit.exe -device open -id default_id2168 -new  ...
*** Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       gambit
Server name:   PC-201001121014
License path:  C:Fluent.Inclicensentx86..license.dat
FLEXlm error:  -15,10.  System Error: 10061 "WinSock: Connection refused"
available at "www.macrovision.com".
Feature:       gambit-addon
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.00 cpu second(s), 101792 maximum memory.
发表于 2010-2-1 14:42:52 | 显示全部楼层
License错误
把crack中的License放到安装目录License文件下的ntx86文件夹下,就可以了
