查看: 7890|回复: 5
not referenced by grid错误
发表于 2010-4-19 19:24:33 | 显示全部楼层 |阅读模式
请大家帮帮忙看看下边两个错误,先谢过了
gambit导出的mesh文件读入fluent中出错:
(1)Reading "C:\Documents and Settings\Administrator\桌面\msh&cas\z-1.2-0.8-0.8.msh"...
1488573 nodes.
  355642 mixed wall faces, zone  3.
  152722 mixed wall faces, zone  4.
     136 mixed outflow faces, zone  5.
     112 mixed velocity-inlet faces, zone  6.
3411022 mixed interior faces, zone  8.
1221776 hexahedral cells, zone  2.
Interrupting...
1522704 hexahedral cells, zone  1.
Building...
     grid,
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
Error Object: ()
(2)Reading "C:\Documents and Settings\Administrator\桌面\msh&cas\z-1.5-0.5-0.8.msh"...
       Clearing partially read grid.
1824309 nodes.
     168 mixed wall faces, zone  3.
  384338 mixed wall faces, zone  4.
  190338 mixed wall faces, zone  5.
    3840 mixed outflow faces, zone  6.
     168 mixed velocity-inlet faces, zone  7.
4278686 mixed interior faces, zone  9.
1522704 hexahedral cells, zone  2.
Building...
     grid,
     materials,
     interface,
     domains,
     zones,
        default-interior
        inlet
        outlet
        wall-diff
        wall
        new_wall
        fluid
        Skipping zone default-interior (not referenced by grid).
        Skipping zone inlet (not referenced by grid).
        Skipping zone outlet (not referenced by grid).
        Skipping zone wall-diff (not referenced by grid).
        Skipping zone wall (not referenced by grid).
        Skipping zone new_wall (not referenced by grid).
        Skipping zone fluid (not referenced by grid).
     shell conduction zones,
Done.
 楼主| 发表于 2010-4-19 20:14:02 | 显示全部楼层
第一个问题自己解决了
重新划分了网格 减小了网格数
发表于 2011-2-21 18:15:49 | 显示全部楼层
楼主,你第二个问题解决了吗?我也碰到一样的问题了
发表于 2012-8-1 11:47:10 | 显示全部楼层
同求
发表于 2012-8-17 09:36:35 | 显示全部楼层
同求
发表于 2017-7-14 22:14:58 | 显示全部楼层
同求
