查看: 1767|回复: 2
求助燃烧室燃烧问题
发表于 2010-4-30 10:36:01 | 显示全部楼层 |阅读模式
燃烧室燃烧模拟,迭代结果不收敛,问题可能处在什么地方?如何改正?此外做导弹飞行阻力模拟试验,平面问题,问题如下:  7 1.4302e+03 2.7019e+05 8.2050e+05 2.0465e+07 4.5467e-03  0:02:53   93
divergence detected - temporarily reducing Courant number to 0.5
and trying again...
time step reduced in 32 cells
absolute pressure limited to 5.000000e+010 in 26 cells on zone 2
temperature limited to 5.000000e+003 in 359 cells on zone 2
     8 4.5385e+05 8.1769e+07 1.1784e+08 7.2466e+09 7.0008e-03  0:02:17   92
and trying again...
time step reduced in 85 cells
absolute pressure limited to 1.000000e+000 in 2 cells on zone 2
absolute pressure limited to 5.000000e+010 in 102 cells on zone 2
temperature limited to 5.000000e+003 in 483 cells on zone 2
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 1 cells
Error: Floating point error: invalid number
Error Object: ()
这是怎么回事?问题在哪?如何解决?
跪谢
发表于 2010-4-30 13:41:27 | 显示全部楼层
reduce relaxaion factor to a very small number, p=0.1, T=0.1 etc
发表于 2010-4-30 13:46:20 | 显示全部楼层
这么做不解决问题。通常是分析者对物理问题的理解有问题,所建立的计算模型有问题,也就是物理模型的问题,而不是离散格式或求解方法的问题。
