查看: 7451|回复: 8
[求助]hummingbird exceed 10 的安装问题
发表于 2006-3-25 13:39:12 | 显示全部楼层 |阅读模式
当我安装humming bird exceed 10时,会跳出来error
"the evaluation period for exceed? 10"
" the wizard was interrupted before exceed? 10
your system has not been modified.to complete installation at another time , please run setup again."
请高手帮帮忙
我上google search 了
只找到一个相关的
但是我找不到
Note: 1: 2318 2 这一行
急需exceed 来运行 gambit .
谢谢帮忙
[br][br][以下内容由 tida 在 2006年03月25日 01:43pm 时添加] [br]
我用的是 winxp pro sp2
fluent 6.2.12
gambit 2.2[br][br][以下内容由 tida 在 2006年03月25日 06:09pm 时添加] [br]
=== Verbose logging started: 3/25/2006  17:31:54  Build type: SHIP UNICODE 3.01.4000.2435  Calling process: C:\Exceed.v10\hs-h1032\Setup.exe ===
MSI (c) (3C:E0) [17:31:54:967]: Resetting cached policy values
MSI (c) (3C:E0) [17:31:54:967]: Machine policy value ';Debug'; is 0
MSI (c) (3C:E0) [17:31:54:967]: ******* RunEngine:
           ******* Product: C:\Exceed.v10\hs-h1032\Exceed 10.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (3C:E0) [17:31:54:977]: Machine policy value ';DisableUserInstalls'; is 0
MSI (c) (3C:E0) [17:31:55:177]: SOFTWARE RESTRICTION POLICY: Verifying package --> ';C:\Exceed.v10\hs-h1032\Exceed 10.msi'; against software restriction policy
MSI (c) (3C:E0) [17:31:55:177]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (3C:E0) [17:31:55:177]: SOFTWARE RESTRICTION POLICY: C:\Exceed.v10\hs-h1032\Exceed 10.msi is not digitally signed
MSI (c) (3C:E0) [17:31:55:187]: SOFTWARE RESTRICTION POLICY: C:\Exceed.v10\hs-h1032\Exceed 10.msi is permitted to run at the ';unrestricted'; authorization level.
MSI (c) (3C:E0) [17:31:55:668]: Cloaking enabled.
MSI (c) (3C:E0) [17:31:55:668]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (3C:E0) [17:31:55:698]: End dialog not enabled
MSI (c) (3C:E0) [17:31:55:698]: Original package ==> C:\Exceed.v10\hs-h1032\Exceed 10.msi
MSI (c) (3C:E0) [17:31:55:698]: Package we';re running from ==> C:\WINDOWS\TEMP\1abef4.msi
MSI (c) (3C:E0) [17:31:55:778]: APPCOMPAT: looking for appcompat database entry with ProductCode ';{B3A51E4B-F165-4930-A1BD-3A9B519BC1D8}';.
MSI (c) (3C:E0) [17:31:55:778]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (3C:E0) [17:31:55:798]: MSCOREE not loaded loading copy from system32
MSI (c) (3C:E0) [17:31:55:798]: Machine policy value ';TransformsSecure'; is 0
MSI (c) (3C:E0) [17:31:55:798]: User policy value ';TransformsAtSource'; is 0
MSI (c) (3C:E0) [17:31:55:798]: Note: 1: 2205 2:  3: MsiFileHash
MSI (c) (3C:E0) [17:31:55:798]: Machine policy value ';DisablePatch'; is 0
MSI (c) (3C:E0) [17:31:55:798]: Machine policy value ';AllowLockdownPatch'; is 0
MSI (c) (3C:E0) [17:31:55:798]: Machine policy value ';DisableLUAPatching'; is 0
MSI (c) (3C:E0) [17:31:55:798]: Machine policy value ';DisableFlyWeightPatching'; is 0
MSI (c) (3C:E0) [17:31:55:798]: Looking for file transform: C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst
MSI (c) (3C:E0) [17:31:55:818]: Original transform ==> C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst
MSI (c) (3C:E0) [17:31:55:818]: Transform we';re running from ==> C:\WINDOWS\TEMP\1abef5.mst
MSI (c) (3C:E0) [17:31:55:818]: SOFTWARE RESTRICTION POLICY: Verifying transform --> ';C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst'; against software restriction policy
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: SOFTWARE RESTRICTION POLICY: C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst is not digitally signed
MSI (c) (3C:E0) [17:31:55:818]: SOFTWARE RESTRICTION POLICY: C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst is permitted to run at the ';unrestricted'; authorization level.
MSI (c) (3C:E0) [17:31:55:818]: Validating transform ';C:\WINDOWS\TEMP\1abef5.mst'; with validation bits 0
MSI (c) (3C:E0) [17:31:55:818]: Transform ';C:\WINDOWS\TEMP\1abef5.mst'; is valid.
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2205 2:  3: Patch
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2205 2:  3: PatchPackage
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: _Tables 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: _Columns 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: Media 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: File 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: TRANSFORM: 'atchPackage'; table is missing or empty.  No pre-transform fixup necessary.
MSI (c) (3C:E0) [17:31:55:818]: TRANSFORM: Applying regular transform to database.
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: ActionText 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (3C:E0) [17:31:55:818]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: AppId 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Binary 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: CheckBox 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ComboBox 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Component 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Control 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ListBox 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: CreateFolder 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: CustomAction 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Dialog 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Directory 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Registry 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Font 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: DrLocator 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Environment 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Error 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Feature 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: FeatureComponents 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: File 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummConfig 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummMigrateFile 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummMigratePath 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummMigrateReg 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: IniFile 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: LockPermissions 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: MIME 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Media 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ModuleComponents 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ModuleDependency 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ModuleSignature 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ProgId 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: RemoveRegistry 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: SconfigFeatComp 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ServiceControl 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: ServiceInstall 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Shortcut 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: UIText 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Upgrade 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: Verb 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: _HCLSHORTN 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: _Validation 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: SconfigProp2 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: SconfigValid2 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummProducts 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummFeatureMap 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummFolderCondition 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummIconMap 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummFontMap 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: HummDirServicesMap 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (c) (3C:E0) [17:31:55:828]: APPCOMPAT: looking for appcompat database entry with ProductCode ';{B3A51E4B-F165-4930-A1BD-3A9B519BC1D8}';.
MSI (c) (3C:E0) [17:31:55:828]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (3C:E0) [17:31:55:828]: Transforms are not secure.
MSI (c) (3C:E0) [17:31:55:828]: Transforming table Property.
MSI (c) (3C:E0) [17:31:55:828]: Command Line: ACTION=INSTALL PID=Ex TRANSFORMS=C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst CURRENTDIRECTORY=C:\Exceed.v10\hs-h1032 CLIENTUILEVEL=0 CLIENTPROCESSID=3388
MSI (c) (3C:E0) [17:31:55:828]: PROPERTY CHANGE: Adding PackageCode property. Its value is ';{51916D72-B4FC-450B-BD66-F8CC6F7F62FC}';.
MSI (c) (3C:E0) [17:31:55:828]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is ';C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst';.
MSI (c) (3C:E0) [17:31:55:848]: Product Code passed to Engine.Initialize:           ';';
MSI (c) (3C:E0) [17:31:55:848]: Product Code from property table before transforms: ';{B3A51E4B-F165-4930-A1BD-3A9B519BC1D8}';
MSI (c) (3C:E0) [17:31:55:848]: Product Code from property table after transforms:  ';{B3A51E4B-F165-4930-A1BD-3A9B519BC1D8}';
MSI (c) (3C:E0) [17:31:55:848]: Product not registered: beginning first-time install
MSI (c) (3C:E0) [17:31:55:848]: PROPERTY CHANGE: Adding ProductState property. Its value is ';-1';.
MSI (c) (3C:E0) [17:31:55:848]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (3C:E0) [17:31:55:848]: User policy value ';SearchOrder'; is ';nmu';
MSI (c) (3C:E0) [17:31:55:848]: Adding new sources is allowed.
MSI (c) (3C:E0) [17:31:55:848]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is ';1';.
MSI (c) (3C:E0) [17:31:55:848]: Package name extracted from package path: ';Exceed 10.msi';
MSI (c) (3C:E0) [17:31:55:848]: Package to be registered: ';Exceed 10.msi';
MSI (c) (3C:E0) [17:31:55:848]: Note: 1: 2729
MSI (c) (3C:E0) [17:31:55:888]: Note: 1: 2729
MSI (c) (3C:E0) [17:31:55:888]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Modifying ALLUSERS property. Its current value is ';2';. Its new value: ';1';.
MSI (c) (3C:E0) [17:31:55:888]: Machine policy value ';DisableMsi'; is 0
MSI (c) (3C:E0) [17:31:55:888]: Machine policy value ';AlwaysInstallElevated'; is 0
MSI (c) (3C:E0) [17:31:55:888]: User policy value ';AlwaysInstallElevated'; is 0
MSI (c) (3C:E0) [17:31:55:888]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (3C:E0) [17:31:55:888]: Running product ';{B3A51E4B-F165-4930-A1BD-3A9B519BC1D8}'; with elevated privileges: Product is assigned.
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Adding ACTION property. Its value is ';INSTALL';.
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Adding PID property. Its value is ';Ex';.
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is ';C:\Exceed.v10\hs-h1032';.
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is ';0';.
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is ';3388';.
MSI (c) (3C:E0) [17:31:55:888]: TRANSFORMS property is now: C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst
MSI (c) (3C:E0) [17:31:55:888]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is ';110';.
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Application Data
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Favorites
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\NetHood
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\My Documents
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\PrintHood
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Recent
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\SendTo
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Templates
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Local Settings\Application Data
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\My Documents\My Pictures
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Start Menu\Programs\Administrative Tools
MSI (c) (3C:E0) [17:31:55:898]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Start Menu\Programs\Startup
MSI (c) (3C:E0) [17:31:55:908]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Start Menu\Programs
MSI (c) (3C:E0) [17:31:55:908]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\patrick\Desktop
MSI (c) (3C:E0) [17:31:55:908]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
MSI (c) (3C:E0) [17:31:55:908]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (3C:E0) [17:31:55:908]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (3C:E0) [17:31:55:908]: MSCOREE not loaded loading copy from system32
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding Privileged property. Its value is ';1';.
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding USERNAME property. Its value is ';tida';.
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is '; ';.
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding DATABASE property. Its value is ';C:\WINDOWS\TEMP\1abef4.msi';.
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is ';C:\Exceed.v10\hs-h1032\Exceed 10.msi';.
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding SourceDir property. Its value is ';C:\Exceed.v10\hs-h1032\';.
MSI (c) (3C:E0) [17:31:55:918]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is ';C:\Exceed.v10\hs-h1032\';.
MSI (c) (3C:1C) [17:31:55:968]: PROPERTY CHANGE: Adding VersionHandler property. Its value is ';3.01';.
=== Logging started: 3/25/2006  17:31:56 ===
MSI (c) (3C:E0) [17:31:56:038]: Note: 1: 2205 2:  3: PatchPackage
MSI (c) (3C:E0) [17:31:56:038]: Machine policy value ';DisableRollback'; is 0
MSI (c) (3C:E0) [17:31:56:038]: User policy value ';DisableRollback'; is 0
MSI (c) (3C:E0) [17:31:56:038]: PROPERTY CHANGE: Adding UILevel property. Its value is ';5';.
MSI (c) (3C:E0) [17:31:56:038]: Doing action: INSTALL
Action 17:31:56: INSTALL.
Action start 17:31:56: INSTALL.
MSI (c) (3C:E0) [17:31:56:058]: UI Sequence table ';InstallUISequence'; is present and populated.
MSI (c) (3C:E0) [17:31:56:058]: Running UISequence
MSI (c) (3C:E0) [17:31:56:058]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is ';INSTALL';.
MSI (c) (3C:E0) [17:31:56:058]: Skipping action: UserIni_FixupProductNameTM (condition is false)
MSI (c) (3C:E0) [17:31:56:058]: Skipping action: ISSetAllUsers (condition is false)
MSI (c) (3C:E0) [17:31:56:058]: Doing action: UserIni_SpecialInstallConditionsEx
Action 17:31:56: UserIni_SpecialInstallConditionsEx.
Action start 17:31:56: UserIni_SpecialInstallConditionsEx.
MSI (c) (3C:78) [17:31:56:078]: Invoking remote custom action. DLL: C:\WINDOWS\TEMP\MSI9F.tmp, Entrypoint: Action_SpecialInstallConditionsEx
MSI (c) (3C:7C) [17:31:56:088]: Cloaking enabled.
MSI (c) (3C:7C) [17:31:56:088]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (3C:7C) [17:31:56:088]: Connected to service for CA interface.
MSI (c) (3C!E8) [17:31:56:409]: Note: 1: 2235 2:  3: Property 4: SELECT `Property`, `Value` FROM `_Property`
Action ended 17:31:56: UserIni_SpecialInstallConditionsEx. Return value 1.
MSI (c) (3C:E0) [17:31:56:429]: Skipping action: ForceNonAdvertisedForTSEInstall (condition is false)
MSI (c) (3C:E0) [17:31:56:429]: Doing action: DisableCurrentUserChoice
Action 17:31:56: DisableCurrentUserChoice.
Action start 17:31:56: DisableCurrentUserChoice.
MSI (c) (3C:E0) [17:31:56:429]: PROPERTY CHANGE: Adding GRAYOUTALLUSER property. Its value is ';1';.
Action ended 17:31:56: DisableCurrentUserChoice. Return value 1.
MSI (c) (3C:E0) [17:31:56:429]: Skipping action: UserIni_HideUserSelectDlg (condition is false)
MSI (c) (3C:E0) [17:31:56:429]: Doing action: UserIni_CheckSingleInstance
Action 17:31:56: UserIni_CheckSingleInstance.
Action start 17:31:56: UserIni_CheckSingleInstance.
MSI (c) (3CC) [17:31:56:459]: Invoking remote custom action. DLL: C:\WINDOWS\TEMP\MSIA0.tmp, Entrypoint: Action_CheckSingleInstance
MSI (c) (3C!84) [17:31:56:509]: PROPERTY CHANGE: Modifying HCL_INSTALL_ACTIVE property. Its current value is ';0';. Its new value: ';1';.
Action ended 17:31:56: UserIni_CheckSingleInstance. Return value 1.
MSI (c) (3C:E0) [17:31:56:519]: Doing action: UserIni_ClearThisInstallAsActive
Action 17:31:56: UserIni_ClearThisInstallAsActive.
Action start 17:31:56: UserIni_ClearThisInstallAsActive.
MSI (c) (3C:E0) [17:31:56:519]: PROPERTY CHANGE: Deleting HCL_AM_ACTIVE_INSTALL property. Its current value is ';0';.
Action ended 17:31:56: UserIni_ClearThisInstallAsActive. Return value 1.
MSI (c) (3C:E0) [17:31:56:519]: Doing action: UserIni_SpecialInstallConditions
Action 17:31:56: UserIni_SpecialInstallConditions.
Action start 17:31:56: UserIni_SpecialInstallConditions.
MSI (c) (3C:B8) [17:31:56:539]: Invoking remote custom action. DLL: C:\WINDOWS\TEMP\MSIA1.tmp, Entrypoint: Action_SpecialInstallConditions
MSI (c) (3C!18) [17:31:56:589]: PROPERTY CHANGE: Adding PROP_WORKSTATION property. Its value is ';WinNT';.
MSI (c) (3C!18) [17:31:56:589]: PROPERTY CHANGE: Adding WINSOCK2SUPPORTED property. Its value is ';1';.
MSI (c) (3C!18) [17:31:56:599]: PROPERTY CHANGE: Adding USEROKTOINSTALLNFS property. Its value is ';1';.
MSI (c) (3C!18) [17:31:56:599]: PROPERTY CHANGE: Adding UserHasAdequatePermissionForNFS property. Its value is ';1';.
Action ended 17:31:56: UserIni_SpecialInstallConditions. Return value 1.
MSI (c) (3C:E0) [17:31:56:609]: Doing action: CheckProductExpired
Action 17:31:56: CheckProductExpired.
Action start 17:31:56: CheckProductExpired.
MSI (c) (3C:34) [17:31:56:629]: Invoking remote custom action. DLL: C:\WINDOWS\TEMP\MSIA2.tmp, Entrypoint: CheckProductExpired
MSI (c) (3C!10) [17:31:56:699]: PROPERTY CHANGE: Adding Hcl_ProductExpired property. Its value is ';ErrorAfterEndDate';.
MSI (c) (3C!10) [17:31:56:699]: PROPERTY CHANGE: Adding HclEval property. Its value is ';1';.
Action ended 17:31:56: CheckProductExpired. Return value 1.
MSI (c) (3C:E0) [17:31:56:709]: Doing action: LaunchConditions
Action 17:31:56: LaunchConditions. Evaluating launch conditions
Action start 17:31:56: LaunchConditions.
Info 2898.Tahoma8, Tahoma, 1
The Evaluation period for Exceed?10
MSI (c) (3C:E0) [17:31:58:111]: Product: Hummingbird Exceed -- The Evaluation period for Exceed?10
Action ended 17:31:58: LaunchConditions. Return value 3.
MSI (c) (3C:E0) [17:31:58:131]: Doing action: SetupCompleteError
Action 17:31:58: SetupCompleteError.
Action start 17:31:58: SetupCompleteError.
Info 2898.TahomaBold10, Tahoma, 1
Action 17:31:58: SetupCompleteError. Dialog created
MSI (c) (3C:1C) [17:31:58:201]: Entering MsiProvideComponentFromDescriptor. Descriptor: ';]gAVn-}f(ZXfeAR6.jiHandWritingFiles>RMn1s[Rh9@Iqc3L`JQB,, PathBuf: 13ECA0, pcchPathBuf: 13EC9C, pcchArgsOffset: 13EBFC
MSI (c) (3C:1C) [17:31:58:211]: MsiProvideComponentFromDescriptor is returning: 0
MSI (c) (3C:1C) [17:31:58:271]: Note: 1: 2731 2: 0
Action ended 17:31:59: SetupCompleteError. Return value 2.
Action ended 17:31:59: INSTALL. Return value 3.
MSI (c) (3C:E0) [17:31:59:403]: Destroying RemoteAPI object.
MSI (c) (3C:7C) [17:31:59:413]: Custom Action Manager thread ending.
Property(C): UI_PRESERVEOLDSETTINGS = 1
Property(C): Privileged = 1
Property(C): VersionNT = 501
Property(C): ALLUSERS = 1
Property(C): NewFolder = NewFolder-NotUsed
Property(C): AdminCustomType = Copy
Property(C): _IsMaintenance = Change
Property(C): AgreeToLicense = No
Property(C): ApplicationUsers = AllUsers
Property(C): USERNAME = tida
Property(C): COMPANYNAME =
Property(C): SetupType = Typical
Property(C): _IsSetupTypeMin = Typical
Property(C): METERINGRETRYINTERVAL = #10
Property(C): METERINGRETRYCOUNT = #5
Property(C): _UserDirLocationRb = PerUser
Property(C): _EodClientInstallRb = No
Property(C): GRAYOUTALLUSER = 1
Property(C): UI_SHOWEODCLIENTINSTALLDLG = 1
Property(C): FileLanguage = 1033
Property(C): PERUSERUNINSTALLTYPE = KILLALL=1 UILEVEL=NONE CHILDUILEVEL=NONE SAFEMULTIUSERCHILDUNINSTALL=1 KEEPACTIVEFOLDERS=1
Property(C): UI_SHOWUSERSELECTDLG = 1
Property(C): SystemFolder = C:\WINDOWS\system32\
Property(C): SourceDir = C:\Exceed.v10\hs-h1032\
Property(C): ProgramFilesFolder = C:\Program Files\
Property(C): AppDataFolder = C:\Documents and Settings\patrick\Application Data\
Property(C): CommonFilesFolder = C:\Program Files\Common Files\
Property(C): DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property(C): FontsFolder = C:\WINDOWS\Fonts\
Property(C): FavoritesFolder = C:\Documents and Settings\patrick\Favorites\
Property(C): NetHoodFolder = C:\Documents and Settings\patrick\NetHood\
Property(C): PersonalFolder = C:\Documents and Settings\patrick\My Documents\
Property(C): PrintHoodFolder = C:\Documents and Settings\patrick\PrintHood\
Property(C): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(C): RecentFolder = C:\Documents and Settings\patrick\Recent\
Property(C): SendToFolder = C:\Documents and Settings\patrick\SendTo\
Property(C): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(C): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(C): System16Folder = C:\WINDOWS\system\
Property(C): TempFolder = C:\WINDOWS\TEMP\
Property(C): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(C): WindowsFolder = C:\WINDOWS\
Property(C): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(C): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(C): LocalAppDataFolder = C:\Documents and Settings\patrick\Local Settings\Application Data\
Property(C): MyPicturesFolder = C:\Documents and Settings\patrick\My Documents\My Pictures\
Property(C): DiskPrompt = Disk containing source for Hummingbird Exceed 10
Property(C): ALLOWBROWSE = 1
Property(C): APPS_TEST = Yes
Property(C): Registration = No
Property(C): UpgradeCode = {20D7521D-3239-4B54-B36E-48BB3FD5F1ED}
Property(C): ProductName = Hummingbird Exceed
Property(C): DialogCaption = Hummingbird Exceed Setup for Windows Installer
Property(C): ProductVersion = 10.0.0.0
Property(C): ProductID = None
Property(C): DefaultUIFont = Tahoma8
Property(C): ProgressType0 = install
Property(C): ARPHELPLINK = http://www.hummingbird.com/support
Property(C): ARPHELPTELEPHONE = North America 1-877-FLY-HUMM (worldwide +1.416.496.2200)
Property(C): Display_IsBitmapDlg = 1
Property(C): ErrorDialog = SetupError
Property(C): InstallChoice = AR
Property(C): INSTALLLEVEL = 100
Property(C): Manufacturer = Hummingbird Ltd.
Property(C): PIDTemplate = 12345<&#35;&#35;&#35;-%%%%%%%>@@@@@
Property(C): ProgressType1 = Installing
Property(C): ProgressType2 = installed
Property(C): ProgressType3 = installs
Property(C): ReinstallModeText = omus
Property(C): ARPCOMMENTS = Hummingbird Exceed Setup for Windows Installer
Property(C): ARPCONTACT = Hummingbird Ltd.
Property(C): ARPINSTALLLOCATION = HCL_HOME_ROOT
Property(C): ARPNOREPAIR = 0
Property(C): ARPURLINFOABOUT = http://www.hummingbird.com
Property(C): ARPURLUPDATEINFO = http://www.hummingbird.com
Property(C): ProductCode = {B3A51E4B-F165-4930-A1BD-3A9B519BC1D8}
Property(C): ProdId = 61
Property(C): RegPathVersion = 10.00
Property(C): SconfigFontSupport = 1
Property(C): SecureCustomProperties = HCL_INSTALL_ACTIVE;ADMINSHAREDSUPPORTED;ISWORKSTATION;ALLOWBROWSE;ISSHAREDDIRROP_WORKSTATION;WINSOCK2SUPPORTED;MMCINSTALLED;UI_LANGDEFAULT;UI_INSTALLLANGUAGES;VALIDLANGSELECTED;UI_MULTIPLELANG;FOUNDEXISTINGLANG;MAJORUPGRADE;OLDPRODUCTCODE;OLDREGPATHVERSION;OLDPRODUCTVERSION;INSTALLEODCLIENTROPSHELLEXEC;EODSILENTINSTALL;FOUND32BITVER;FULLNFSSERVER;UP7;UP71;UP711;UP8;UP9;XUP10EX;XUP10HE;XUP10NC;XUP10NL;XUP711EX;XUP711HE;XUP711NC;XUP711NL;XUP71EX;XUP71HE;XUP71NC;XUP71NL;XUP7EX;XUP7HE;XUP7NC;XUP7NL;XUP8EX;XUP8HE;XUP8NC;XUP8NL;XUP9EX;XUP9HE;XUP9NC;XUP9NL;UI_PRESERVEOLDSETTINGS;METERINGRETRYCOUNT;METERINGRETRYINTERVAL;METERINGURL;WMIINSTALLED;HHINSTALLED;DISABLEPERUSERSETTINGS;SAMEVERSIONUPGRADEDETECTED
Property(C): DEFAULT_MIGRATE_ENABLE = 1
Property(C): PatchVersion = 10.0.0.0
Property(C): HCL_INSTALL_ACTIVE = 1
Property(C): HCL_ALLOW_INSTALL = 1
Property(C): UsrSetupReLogonList = HCL_HostAccess_HN
Property(C): UsrSetupPCAList = HCL_Exceed=PCA_Exceed_Xconfig;HCL_SystemAdmin_JconfigD=PCA_JconfigD
Property(C): RegVersion = 10.00
Property(C): ProductVBSAddress = http://www.hummingbird.com/products/humupd/nc/expatch1000.vbs
Property(C): HCLArpString = Hummingbird Exceed 10
Property(C): ARPPRODUCTICON = humicon10.exe
Property(C): AdminList = setup.exe;*.sms;ExceedTSE.mst
Property(C): Hcl_QueryKillCompList = co_Inetd_Inetd32_exe_95,inetd32.exe;co_Inetd_Inetd32_exe_NT,inetd32.exe
Property(C): Hcl_QueryKillCompList_Rem = co_Inetd_Inetd32_exe_95,inetd32.exe;co_Inetd_Inetd32_exe_NT,inetd32.exe
Property(C): ProductLanguage = 1033
Property(C): HumProdPrefix = Ex
Property(C): VVerStr = 10
Property(C): UI_LANGUAGE_SearchMethod = 0
Property(C): METERINGRETRYCOUNT_MAX = 9999
Property(C): METERINGRETRYCOUNT_MIN = 0
Property(C): METERINGRETRYINTERVAL_MAX = 9999
Property(C): METERINGRETRYINTERVAL_MIN = 0
Property(C): LicenseFile = HummConn.lic
Property(C): FullProductName = Exceed?10[~]
Property(C): DlgProductName = Exceed?10[~]
Property(C): UI_INSTALLLANGUAGES = 1031 1033 1034 1036 1040 1046
Property(C): UI_INSTALLLANGUAGESSTR = deu eng esp fra ita prt
Property(C): UI_MULTIPLELANG = 6
Property(C): PackageCode = {51916D72-B4FC-450B-BD66-F8CC6F7F62FC}
Property(C): TRANSFORMS = C:\Exceed.v10\hs-h1032\Installer\Ex\1033.mst
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): ACTION = INSTALL
Property(C): PID = Ex
Property(C): CURRENTDIRECTORY = C:\Exceed.v10\hs-h1032
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 3388
Property(C): VersionDatabase = 110
Property(C): VersionMsi = 3.01
Property(C): WindowsBuild = 2600
Property(C): ServicePackLevel = 2
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): WindowsVolume = C:\
Property(C): RemoteAdminTS = 1
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): Intel = 15
Property(C): PhysicalMemory = 768
Property(C): VirtualMemory = 1550
Property(C): AdminUser = 1
Property(C): LogonUser = patrick
Property(C): UserSID = S-1-5-21-1275210071-813497703-854245398-1003
Property(C): UserLanguageID = 1033
Property(C): ComputerName = TIDA
Property(C): SystemLanguageID = 2052
Property(C): ScreenX = 1024
Property(C): ScreenY = 768
Property(C): CaptionHeight = 19
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 16
Property(C): ColorBits = 16
Property(C): TTCSupport = 1
Property(C): Time = 17:31:59
Property(C): Date = 3/25/2006
Property(C): MsiWin32AssemblySupport = 5.1.2600.2180
Property(C): RedirectedDllSupport = 2
Property(C): DATABASE = C:\WINDOWS\TEMP\1abef4.msi
Property(C): OriginalDatabase = C:\Exceed.v10\hs-h1032\Exceed 10.msi
Property(C): SOURCEDIR = C:\Exceed.v10\hs-h1032\
Property(C): VersionHandler = 3.01
Property(C): UILevel = 5
Property(C): EXECUTEACTION = INSTALL
Property(C): PROP_WORKSTATION = WinNT
Property(C): WINSOCK2SUPPORTED = 1
Property(C): USEROKTOINSTALLNFS = 1
Property(C): UserHasAdequatePermissionForNFS = 1
Property(C): Hcl_ProductExpired = ErrorAfterEndDate
Property(C): HclEv&#97;l = 1
=== Logging stopped: 3/25/2006  17:31:59 ===
MSI (c) (3C:E0) [17:31:59:473]: Note: 1: 1708
MSI (c) (3C:E0) [17:31:59:473]: Product: Hummingbird Exceed -- Installation operation failed.
MSI (c) (3C:E0) [17:31:59:473]: Attempting to delete file C:\WINDOWS\TEMP\1abef5.mst
MSI (c) (3C:E0) [17:31:59:503]: Grabbed execution mutex.
MSI (c) (3C:E0) [17:31:59:503]: Cleaning up uninstalled install packages, if any exist
MSI (c) (3C:E0) [17:31:59:503]: MainEngineThread is returning 1603
=== Verbose logging stopped: 3/25/2006  17:31:59 ===
 楼主| 发表于 2006-3-25 18:31:59 | 显示全部楼层
顶 -0-
帮帮忙 =0=
我找了整天还是没办法 T_T
发表于 2006-3-25 21:19:13 | 显示全部楼层
不过我在安装的时候没有出现问题,不知道这个问题是什么原因!
你是不是先装的exceed,然后再装gambit的,这个顺序不能反了的!
发表于 2006-3-25 21:21:19 | 显示全部楼层
如果找到原因,一定要告诉我们阿!呵呵
 楼主| 发表于 2006-3-26 00:34:23 | 显示全部楼层
-0-
找不到。。
我改用了 v11 就没问题了...
不知道是不是sp2 对 v10版本有问题
我试了两个 v10 file还是不行
好累 =_= 试了好多方法。
发表于 2006-3-26 18:23:18 | 显示全部楼层
你的EXCEED过期了。你可以换个版本安装,或者修改你的系统时间到以前可以安装的时间,装好后再把时间修改回来。[br][br][以下内容由 heaventeen 在 2006年03月29日 03:07pm 时添加] [br]
发表于 2006-9-27 16:09:07 | 显示全部楼层
把系统时间改成2005年就行了
发表于 2006-12-13 12:38:12 | 显示全部楼层
我也有此问题,希望大虾们帮帮忙
急急!!!!!!!
发表于 2006-12-14 11:17:53 | 显示全部楼层
把系统时间该到2005年然后装exceed,装好后,再将系统时间该回,再装gambit,fluent.
