查看: 2656|回复: 0
fluent中加入电场力
发表于 2010-5-21 12:04:33 | 显示全部楼层 |阅读模式
本人要做一个电除尘的FLUENT算例,用的是DPM模型,加入电场力的UDF也已经找到,可以在编译到fluent中后,不知道如何设置电场力参数,望高手指教。谢谢!
另附程序代码如下:
/*  Usage  */
/*DEFINE_DPM_BODY_FORCE( name, p, i) */
/*  Argument Type Description */
/* symbol name UDF name.  */
/* Tracked_Particle *p Pointer to the Tracked_Particle data structure which */
/*  contains data related to the particle being tracked. */
/* int i An index ( 0, 1, or 2) that identifies the Cartesian */
/*   component of the body force that is to be returned by the function */
/* Function returns   */
/* real */
/* UDF for computing the ic force on a charged particle */
#include "udf.h"
#define Q 1.0         /* particle electric charge      */
#define BZ 3.0        /* z component of ic field */
#define TSTART 18.0   /* field applied at t = tstart   */
/* Calculate ic force on charged particle.  ic   */
/* force is particle charge times cross product of particle  */
/* velocity with ic field: Fx= q*bz*Vy,  Fy= -q*bz*Vx  */
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
        real bforce;
        if(P_TIME(p)>=TSTART)
           if(i==0) bforce=Q*BZ*P_VEL(p)[1];
           else if(i==1) bforce=-Q*BZ*P_VEL(p)[0];
        else
           bforce=0.0;
        /* an acceleration should be returned */
        return (bforce/P_MASS(p));
