查看: 4403|回复: 0
UDF求教
发表于 2010-8-12 11:59:11 | 显示全部楼层 |阅读模式
下面有一段UDF,是帮助文档上的:
DEFINE_SDOF_PROPERTIES(delta_missile, prop, dt, time, dtime)
prop[SDOF_MASS] = 907.185;
prop[SDOF_IXX] = 27.116;
prop[SDOF_IYY] = 488.094;
prop[SDOF_IZZ] = 488.094;
/* add injector forces, moments */
register real dfront = fabs (DT_CG (dt)[2] -
Release 12.0
c ANSYS, Inc. January 26, 2009 2-223
DEFINE Macros
(0.179832*DT_THETA (dt)[1]));
register real dback = fabs (DT_CG (dt)[2] +
(0.329184*DT_THETA (dt)[1]));
if (dfront <= 0.100584)
prop[SDOF_LOAD_F_Z] = 10676.0;
prop[SDOF_LOAD_M_Y] = -1920.0;
if (dback <= 0.100584)
prop[SDOF_LOAD_F_Z] += 42703.0;
prop[SDOF_LOAD_M_Y] += 14057.0;
printf ("\ndelta_missile: updated 6DOF properties");
哪位大侠帮我解答一下,上面的DT_CG (dt)[2],DT_THETA (dt)分别是什么意思?文档里有定义的么?可以DT_OMEGA么?
