查看: 3751|回复: 2
Error: heap limit reached. Cannot allocate additional chunks
发表于 2010-10-9 14:25:12 | 显示全部楼层 |阅读模式
出现这个错误是什么意思?会是什么原因造成的?谢谢
发表于 2010-10-28 16:42:29 | 显示全部楼层
我也遇到同样的问题了,不知道楼主问题解决了没?请高手指点,谢谢啦!
发表于 2012-10-28 13:43:46 | 显示全部楼层
从外转过来的:
I have recently come across the same error message in Fluent. I found that it has to do with Fluent's memory.
Particularly, the amount of I/O from the software during simulations. Check how much monitors you are running and how many data sets you are saving during the simulation. You will need to reduce the amount of monitors and/or data sets and run the additional sets again later.
Fluent seems to have errors saving the monitors and keeping the memory in storage, so you need to select only key monitors and data recording. Once the simulation has finished, you can run it again, or continue the simulation, but this time with the other monitors instead. Keep the amount of I/O to a minimum.
