查看: 2169|回复: 0
能量不守恒
发表于 2010-10-18 11:02:32 | 显示全部楼层 |阅读模式
各位专家,我用Fluent模拟平板太阳能集热器,可却发现能量不守恒,这是怎么回事?望能被解答。平板太阳能集热器结构式这样的,heat-wall吸收太阳能辐射,实际处理中设为热流密度,heat-wall下面有八根铜管通以水,水带走热量从而使水温上升。
      heat-wall是我设定的唯一热源,热流密度为500W/m2,面积为1.7860001,因而总的热流量为893.35577W。可不知为何report却报告inlet也有热量流入水中,热流量为308.8743W,可我压根没设inlet为任何热源,我只设它为mass-inlet,流量为0.04kg/s。
即使是这样,可heat-wall和inlet总的热流量为1202W,而有水的温升可知总共需要热量为1511.2401096W。这是怎么回事,多余的热量从何而来。望各位能帮我解答,不胜感激。
        Total Heat Transfer Rate                  (w)
                       heat-wall            893.35577
                           inlet             308.8743
                          outlet             -1420.11
                         wall-al                   -0
                         wall-cu                   -0
                      wall-cu-al            1114.1169
               wall-cu-al-shadow           -1113.7935
                   wall-cu-water            1111.2347
            wall-cu-water-shadow           -1111.2228
                            Area                 (m2)
                       heat-wall            1.7860001
                           inlet        0.00029010928
                          outlet        0.00029010867
                         wall-al            1.7503034
                         wall-cu           0.34348053
                      wall-cu-al          0.037968807
               wall-cu-al-shadow          0.037968807
                   wall-cu-water           0.32456204
            wall-cu-water-shadow           0.32456204
         Average of Facet Values
              Static Temperature                  (k)
                       heat-wall            318.42227
                           inlet                  300
                          outlet            309.05151
                         wall-al            318.95914
                         wall-cu            309.75073
                      wall-cu-al            310.41702
               wall-cu-al-shadow            310.41702
                   wall-cu-water            309.93015
            wall-cu-water-shadow            309.93015
   Material: water-liquidnew (fluid)
      Property                        Units      Method     Value(s)
      Density                         kg/m3      constant   994
      Cp (Specific Heat)              j/kg-k     constant   4174
      Thermal Conductivity            w/m-k      constant   0.625
      Viscosity                       kg/m-s     constant   0.00069999998
      Molecular Weight                kg/kgmol   constant   28.966
