查看: 2464|回复: 0
fluent模拟气固流化床采用欧拉模型并行计算出现问题
发表于 2010-11-1 08:32:04 | 显示全部楼层 |阅读模式
如题,Domain Extents:
   x-coordinate: min (m) = -1.504056e+000, max (m) = 1.504056e+000
   y-coordinate: min (m) = -1.504056e+000, max (m) = 1.504056e+000
   z-coordinate: min (m) = -3.954906e+000, max (m) = 4.000000e+000
共计Level    Cells    Faces    Nodes   Partitions
    0   118973   263258    38429            1
迭代 0.001s间隔。每步迭代 23次, ( courant数=0.01)  在迭代了3步后出现问题如下,一直很困惑,好像是网格的问题,但是不知道如何解决啊
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 3076 cells
    75 4.8345e-01 7.0716e-02 2.1623e-02 6.4105e-02 1.7573e-02 5.0451e-01 4.7495e-02 3.5347e-02 4.8223e-02 5.3105e-04  0:00:10   17
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 2508 cells
    76 4.6065e-01 5.8686e-02 1.6510e-02 5.7279e-02 1.4017e-02 3.4583e-01 3.2057e-02 4.1836e-02 5.8991e-02 7.4475e-04  0:00:07   16
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 3486 cells
    77 1.0186e+00 1.9718e-02 1.4642e-02 1.9111e-02 1.2713e-02 2.0827e-01 2.2457e-02 2.8415e-01 4.0360e-01 5.9720e-04  0:00:09   15
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 1703 cells
    78 4.0658e-01 6.9883e-02 1.2277e-02 6.7578e-02 1.1482e-02 4.0341e-01 1.9761e-02 1.5802e-01 2.0972e-01 6.5258e-04  0:00:06   14
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 2438 cells
    79 4.7345e-01 5.2263e-02 1.0559e-02 4.9648e-02 1.0218e-02 5.6377e-01 1.7629e-02 4.0762e-02 7.3831e-02 5.3690e-04  0:00:07   13
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 2365 cells
  iter continuity  u-phase-1  u-phase-2  v-phase-1  v-phase-2  w-phase-1  w-phase-2  k-phase-1 eps-phase- vf-phase-2     time/iter
    80 4.0495e-01 6.6257e-02 9.9206e-03 6.6314e-02 9.3302e-03 2.4041e-01 1.4873e-02 3.4090e-02 5.3204e-02 4.8348e-04  0:00:05   12
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 2711 cells
    81 3.8580e-01 4.6926e-02 9.3235e-03 4.9785e-02 8.8725e-03 6.8015e-02 1.1986e-02 1.5275e-02 3.5898e-02 5.2936e-04  0:00:06   11
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 2956 cells
    82 5.6706e-01 4.9482e-02 8.9290e-03 5.2217e-02 8.8058e-03 2.1373e-01 1.2180e-02 3.9639e-02 6.7662e-02 1.1788e-03  0:00:04   10
Error: Floating point error: invalid number
Error Object: #f
Balancing not successful.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 8 bytes: Invalid argument
s!
        ***You are trying to partition a graph into too many parts!
        ***Cannot bisect a graph with 0 vertices!
        ***unable to read the cmd header on the pmi context, Undefined dynamic error code.
        ***You are trying to partitiounable to read the cmd header on the pmi context, Undefined dynamic error code.
        ***Cannot bisect a graph with 0 vertiunable to read the cmd header on the pmi context, Undefined dynamic error code.
ces!
received suspend command for a pmi context that doesn't exist: unmatched id = 5
received suspend command for a pmi context that doesn't exist: unmatched id = 4
received suspend command for a pmi context that doesn't exist: unmatched id = 3
job aborted:
rank: node: exit code[: error message]
0: y-1pbwn1t8x2e: -1073741819: process 0 exited without calling finalize
1: y-1pbwn1t8x2e: -1073741819: process 1 exited without calling finalize
2: y-1pbwn1t8x2e: -1073741819: process 2 exited without calling finalize
3: y-1pbwn1t8x2e: -1073741819: process 3 exited without calling finalize
4: y-1pbwn1t8x2e: -1073741819: process 4 exited without calling finalize
5: y-1pbwn1t8x2e: -1073741819: process 5 exited without calling finalize
received suspend command for a pmi context that doesn't exist: unmatched id = 2
received suspend command for a pmi context that doesn't exist: unmatched id = 0
The Parallel FLUENT process could not be started.
