查看: 6844|回复: 1
请问openfoam下如何算升阻力系数
发表于 2010-12-5 20:40:27 | 显示全部楼层 |阅读模式
这个问题困扰我很久了,一直都得不到满意的答复。我在算一个圆柱绕流问题,想要得到升阻力及系数的情况,之前有人看到网上有人说用function object功能,然后我照着别人的办法设置controlDick文件,但是输出结果只有U和P,并没有我要的升力和阻力,请问有人能告诉我这是什么情况么?我该如何着手?或者说计算升阻力有没有别的办法?希望有达人能详细的介绍一下,不胜感激!
发表于 2010-12-7 17:14:32 | 显示全部楼层
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
|    \\/     M anipulation  |                                                 |
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    location        system;
    object          sampleDict;
// Set output format : choice of
//      xmgr
//      jplot
//      gnuplot
//      raw
setFormat raw;
// Surface output format. Choice of
//      null        : suppress output
//      foamFile    : separate points, faces and values file
//      dx          : DX scalar or vector format
//      vtk         : VTK ascii format
//      raw         : x y z value format for use with e.g. gnuplot 'splot'.
// Note:
// other formats such as obj, stl, etc can also be written (by proxy)
// but without any values!
surfaceFormat raw;
// interpolationScheme. choice of
//      cell          : use cell-centre value only; constant over cells (default)
//      cellPoint     : use cell-centre and vertex values
//      cellPointFace : use cell-centre, vertex and face values.
// 1] vertex values determined from neighbouring cell-centre values
// 2] face values determined using the current face interpolation scheme
//    for the field (linear, gamma, etc.)
interpolationScheme cellPoint;
// Fields to sample.
fields
    p
// Set sampling definition: choice of
//      uniform             evenly distributed points on line
//      face                one point per face intersection
//      midPoint            one point per cell, inbetween two face intersections
//      midPointAndFace     combination of face and midPoint
//      curve               specified points, not nessecary on line, uses
//                          tracking
//      cloud               specified points, uses findCell
// axis: how to write point coordinate. Choice of
// - x/y/z: x/y/z coordinate only
// - xyz: three columns
//  (probably does not make sense for anything but raw)
// - distance: distance from start of sampling line (if uses line) or
//             distance from first specified sampling point
// type specific:
//      uniform, face, midPoint, midPointAndFace : start and end coordinate
//      uniform: extra number of sampling points
//      curve, cloud: list of coordinates
sets
// Surface sampling definition: choice of
//      plane : values on plane defined by point, normal.
//      patch : values on patch.
// 1] patches are not triangulated by default
// 2] planes are always triangulated
// 3] iso-surfaces are always triangulated
surfaces
    airfoil
        type            patch;    // always triangulated
    patchName    Airfoil;
   slat
    type        patch;
    patchName    Slat;
