查看: 3670|回复: 0
求助離心式風扇網格及BC問題
发表于 2011-1-21 00:55:25 | 显示全部楼层 |阅读模式
小弟目前正在進行一個離心式風扇的模擬,將DTF檔匯進ACE+後,跑出這個錯誤訊息
  Arbitrary Interface set Arb_2  processed with maximum gap =   5.696437281002955E-004
  Arbitrary Interface set Arb_3  processed with maximum gap =   2.613380339508165E-004
  Arbitrary Interface set Arb_6  processed with maximum gap =   2.273372666826143E-004
No cross points found(walk)!
我翻了MANUAL,將Arb_2 set的方向改變,重新下去跑,卻出現以下這個錯誤訊息
Incorrect BC patch: covers multiple types with a single record
  BC info: name, key, recordNumber=NONAME       15038        3288
  BC info: name, key, recordNumber=NONAME       15040        3291
Please run split-interfaces utility on this mesh to repair.
If that does not prevent this message, you must run dtf_decompose on your
original mesh to recreate this sim.
Aborting.
但是我再怎麼檢查,這兩個面都是interface,而且我也沒有設定他們為Arbitrary Interface,不知道是哪裡出
了問題?
另外MANUAL裡有說Arbitrary Interface 的連接的兩個面要越單純越好,但是我風扇外側網格面是22個面為
一個Group(Outlet),渦殼內側是11個面為一個Group(Outlet),兩個Group來set Arbitrary Interface,
這應該是造成ERROR的原因之一,請問有什麼方法可以改善的嗎?
因為之前沒學過,加上身邊沒人懂,所以只能自己翻Manual,希望各位高手可以幫我解答,我真的想不出其
他方法了, 感謝各位!!!
