查看: 1616|回复: 2
有没有人做过带有轴流风机风场的模拟?
发表于 2006-7-28 21:16:30 | 显示全部楼层 |阅读模式
我是学暖通的,目前打算做一下一个风冷热泵的空气场的模拟工作。
我看到fluent里面提到轴流风机相关的东西
但是gambit建模不知道怎么建?
希望大家可以教我,谢谢!
 楼主| 发表于 2006-8-6 17:14:47 | 显示全部楼层
有没有人做过带有轴流风机风场的模拟?
希望大家可以教我
发表于 2006-8-7 18:34:51 | 显示全部楼层
有没有人做过带有轴流风机风场的模拟?
Hi,
You can use CAD or Gambit G/turbo tools to create the axial fan geometry.
If you use the CAD tools, you have to export the IGES, STEP, Parasolid format file. This file can be import to Gambit by selecting import option in File menu. Then you have to create mesh for the fluid domains. The domains you created must be two separated domains.Export the mesh file and import it to Fluent. Use MRF method to define the rotate fluid domain and set the fan rotate rate. Completly define the others boundary condition. You can use Fluent post-processing tool to get your results.
