查看: 3509|回复: 0
momentum source 怎么样设置
发表于 2011-3-9 17:12:53 | 显示全部楼层 |阅读模式
本人是cfx初学者,自己编了fortran程序并导入cfx后,在subdomain项下面的momentum source X component项的设置方面存在些疑问。计算迭代到第一步的时候出现问题,有没有高手能够针对需要往cfx里导入fortran程序时momentum source X component怎么样设置给点指引?十分感谢!
下面是错误信息:
OUTER LOOP ITERATION =    1                    CPU SECONDS = 1.048E+01
|       Equation       | Rate | RMS Res | Max Res |  Linear Solution |
| Wallscale            | 0.00 | 2.6E-03 | 1.9E-02 | 11.5  4.4E-02  OK|
| PROBLEM ENCOUNTERED WHEN EXECUTING CFX EXPRESSION LANGUAGE         |
| The CFX expression language was evaluating:                        |
|      "Momentum Source X Component"                                 |
| The problem was:                                                   |
|      User Fortran: BNAM                                            |
| FURTHER INFORMATION                                                |
| The problem was encountered in executing the expression for:       |
| The complete expression is:                                        |
|   fdx(1)                                                           |
| The error occurs on sub-expression:                                |
|   1        |
| BACKGROUND INFORMATION                                             |
| The error was detected at one location. The same problem may be    |
| present at other locations - that has not been investigated.       |
| The following values are for the first location which has the      |
| problem.                                                           |
| END OF DIAGNOSTIC OUTPUT FOR CFX EXPRESSION LANGUAGE               |
Error in subroutine  CEL_CALVAR :
Failure to calculate variable using Expression Language
GETVAR originally called by subroutine  DEF_SOU_MOMU
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Stopped in routine GV_ERROR                                        |
