查看: 5541|回复: 5
wall func. heat tran. coef.是什么啊?
发表于 2011-3-19 17:25:35 | 显示全部楼层 |阅读模式
wall func. heat tran. coef.是什么啊 它和surface heat transfer coef有啥区别啊 谁能帮忙回答下?
发表于 2011-3-20 09:38:09 | 显示全部楼层
不懂,
    顶下......
抛光机http://www.paoguangji8.com 郑州中原抛光机械总厂
 楼主| 发表于 2011-3-20 10:23:34 | 显示全部楼层
回复 2# luntan666 的帖子
多谢帮顶啊
 楼主| 发表于 2011-3-20 18:16:19 | 显示全部楼层
咋没人回答啊 各位大虾啊啊啊
发表于 2011-3-20 19:12:31 | 显示全部楼层
帮你把User's Guide的31.4 Alphabetical Listing of Field Variables and Their Definitions 一节相关内容粘在下面,公式不好贴,自己去查。
Wall Func. Heat Tran. Coef.    is defined by the equation
                 Eq.     (31.4-51)
where Cp  is the specific heat,  kp is the turbulence kinetic energy at point P, and T*  is the dimensionless law-of-the-wall temperature defined in this equation in the separate Theory Guide.
Surface Heat Transfer Coef.    (in the Wall Fluxes... category), as defined in ANSYS FLUENT, is given by the equation
                heff = q / (Twall -  Tref )                       (31.4-40)
where q  is the combined convective and radiative heat flux, Twall is the wall temperature, Tref and  is the reference temperature defined in the Reference Values task page. Please note that  Tref is a constant value that should be representative of the problem. Its unit quantity is the heat-transfer- coefficient.
 楼主| 发表于 2011-3-20 21:00:52 | 显示全部楼层
回复 5# xrs333 的帖子
谢啦
