查看: 4700|回复: 3
[求助]gambit切割时,出现此类警告
发表于 2006-9-12 20:39:03 | 显示全部楼层 |阅读模式
我在用split命令时, 选择了connected,但是出现此类警告,不知道要不要紧,请指教,谢谢!
warnning: connected geometry may be imprinted by the requested operation.
这句话是看的懂,但是不知道具体指的是什么。
 楼主| 发表于 2006-9-13 17:35:43 | 显示全部楼层
很多次切割都这样。搞不清楚!
发表于 2010-6-1 10:32:43 | 显示全部楼层
我也遇到同样问题,有那位大虾帮帮忙
发表于 2011-2-24 09:59:19 | 显示全部楼层
百思论坛有人这么说:
查了下cfd-online, 有人回答如下
1. Imprinting means that lower geometry and connected geometry are affected by the Boolean or split operation being performed.
2. Imprinting leads to a change of names of the connected volumes too. After any split you must recover the names to keep yourself familiar with the composition of your solution domain
也就是說:lower geometry 會因為其 upper geometry的Boolean/split等操作而連帶受到影響, 其僅是一個warning
