查看: 4197|回复: 4
求教关于PFEM(Particle Finite Element Method)更详细的资料
发表于 2012-8-22 22:01:43 | 显示全部楼层 |阅读模式
Introduction to PFEM
1.Lagrangian formulation:
The position and physical properties of the particles are described in terms of the material or referential coordinates and time which is normally used in solid mechanics
2.E ective for solving free-surface flow problems:
a.  Changes in the position and physical properties as the material particles move in free-surface are easy to capture
b. Delaunay tessellation and Alpha shape method ===> mesh
c. Fractional Step Method ===>  fast iterative solver
d.  Finite calculus method ===>  stabilize the incompressible condition
3.Natural for solving solid-fluid interaction problems
 楼主| 发表于 2012-8-22 22:05:37 | 显示全部楼层
introduction
 楼主| 发表于 2012-8-22 22:06:42 | 显示全部楼层
particle based method
 楼主| 发表于 2012-8-22 22:07:58 | 显示全部楼层
finite element method
 楼主| 发表于 2012-8-22 22:09:18 | 显示全部楼层
particles moving and elements updating
