查看: 6315|回复: 1
highspeed wf mach threshold
发表于 2011-7-19 13:23:41 | 显示全部楼层 |阅读模式
我用 cfx计算,出现如下提示:
    ****** Notice ******                           |
| The non-dimensional near wall temperature (T+) has been clipped    |
| for calculation of Wall Heat Transfer Coefficient.                 |
| Boundary Condition : wall                                          |
| T+ clip value      =  1.0000E-10                                   |
| If this situation persists and you are using the High Speed Model, |
| consider enabling Mach number based blending between low speed and |
| high speed wall functions.  You can do so by specifying a Mach     |
| number threshold as follows:                                       |
| EXPERT PARAMETERS:                                                 |
|   highspeed wf mach threshold = 0.1     # default=0.0 (off)        |
| END
请问         highspeed wf mach threshold 在哪呀?找不着。先谢了
 楼主| 发表于 2011-8-18 09:39:02 | 显示全部楼层
我该怎么办?
