查看: 6608|回复: 2
在cfx计算,想把结果(.res)文件导入 fluent中
发表于 2011-7-25 17:08:31 | 显示全部楼层 |阅读模式
我在cfx计算,想把结果(.res)文件导入 fluent中,出现:
> Reading "\"| utility fe2ram -tCFXD -d3 -m0 -zCCL  \"\"E:\qifeng\qifeng14 ssg angularinletvelocity temperature473_001.res\"\"\""...
Error: bad syntax. Usage:
utility fe2ram dimension read_format zoning write_format [inputfile [outputfile]]
dimension: [-d2 | -d3 | -surface]
read_format: [-tANSYS | -tCFX | -tCFXD | -tCFXR | -tCGNS |
  -tFIDAP7 | -tFLUENT4 | -tFLUENT4UNI | -tGAMBIT | -tHYPER |
  -tIDEAS | -tDYNA | -tNASTRAN | -tOIV | -tPATRAN |
  -tPLOT3DB | -tPLOT3DBI | -tPLOT3DF | -tPLOT3DFI | -tPROE |
  -tRAMPANT | -tSTAR16 | -tSTL | -tYAMS | -tFTL |
  -tVRML | -tWAVEFRONT | -tGAF | -tTECPLOT]
  zoning: [-zGROUP | -zID | -zPRESSURE | -zTEMPERATURE | -zNONE]
  default is -zGROUP.
write_format: [-oFIDAP7 | -oRAMPANT]
  default is -zGROUP.
Building...
     mesh
Primitive Error at Node 0:
Partition: cell count = 0; count must be greater than zero.
Primitive Error at Node 1:
Primitive Error at Node 2:
Error:
Error Object: #f
怎么回事?谢谢
 楼主| 发表于 2011-7-26 11:20:18 | 显示全部楼层
难道没有人这么做过?
发表于 2017-10-17 09:36:06 | 显示全部楼层
同问,请大神帮帮忙
