查看: 6632|回复: 0
abaqus CFD问题 system error code 65535
发表于 2011-10-15 14:12:52 | 显示全部楼层 |阅读模式
小弟最近刚装了abaqus 6.11 从网上找了个cfd的实例 但是一submit job就出错
请知道原因的朋友不吝赐教 谢谢
The executable Program aborted with system error code 65535. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
