查看: 2251|回复: 1
Advanced Control of CFX-Flow Parameters
发表于 2012-2-21 15:21:52 | 显示全部楼层 |阅读模式
在cfx的帮助中有
*** INSUFFICIENT MEMORY ALLOCATED ***
Action required:
Depending on what program is running, there then follows a message relating to what memory stack is full. If the program is CFX-FLOW, then the following message is shown:
Re-run CFX-Pre and increase the CDTYPE stack memory factor. Use the Workspace Sizes menu under Advanced Control of CFX-Flow Parameters.
其中Advanced Control of CFX-Flow Parameters选项在哪可以找到,谢了
发表于 2012-2-23 00:02:20 | 显示全部楼层
原帖由 yangyu96 于 2012-2-21 07:21 发表
在cfx的帮助中有
Action required:
Depending on what program is running, there then follows a message relating to what memory stack is full. If the program ...
这个选项倒不知道,
你的内存不够了吧。
