查看: 6678|回复: 2
cfx-ansys workbench流固耦合时遇到的错误
发表于 2012-2-25 21:05:26 | 显示全部楼层 |阅读模式
我按照豆丁网和百度文库里面《流固耦合-双向耦合》教程的指导,做了个流固耦合的例子,在耦合计算时遇到了错误:
ERROR #002100012 has occurred in subroutine cVolSec.               |
| A negative ELEMENT volume has been detected.  This is a fatal      |
| error and execution will be terminated.  The location of the first |
| negative volume is reported below.                                 |
|     Volume   :  -0.1712E-05                                        |
|     Location : (  0.25685E+01,  0.79439E+00,  0.35813E-01)         |
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| CFX encountered the error:                                         |
|                                         0.  A folded mesh has oc-  |
| curred.  This process will shut down as soon as possible.          |
请问有哪位高手可以告诉我是哪里出的错,不胜感激!
CFX_流固双向耦合的实现.pdf
943.84 KB, 下载次数: 1000
发表于 2012-9-1 12:40:05 | 显示全部楼层
学习一下
发表于 2012-9-3 16:47:37 | 显示全部楼层
回复 1# hhzhangfuxing 的帖子
这个是负体积啊,检查一下网格吧
