查看: 15903|回复: 8
fluent计算网格Check没问题。算不了。
发表于 2012-4-16 21:08:53 | 显示全部楼层 |阅读模式
网格用ICEM画的,现在质量已达0.3,之前导入到ANSYS12.0下FLUENT计算,Check Grid Failed 出现左手面问题。现在我将同一网格导入6.26版本,导入后,Check没任何问题。但是计算不超三步必停。请大神们帮忙看一下,谢谢啦~~
   > Reading "E:\MyWork\水上飞机\fluent.msh"...
1884462 nodes.
1839354 hexahedral cells, zone  8.
5473246 quadrilateral interior faces, zone  9.
   22726 quadrilateral symmetry faces, zone  1.
   17754 quadrilateral wall faces, zone 10.
   49152 quadrilateral pressure-far-field faces, zone 11.
Building...
     grid,
     materials,
     interface,
     domains,
     zones,
        far
        aircraft
        symm
        int_fluid
        fluid
     shell conduction zones,
Done.
Grid Check
Domain Extents:
   x-coordinate: min (m) = -3.491000e+005, max (m) = 3.509000e+005
   y-coordinate: min (m) = -3.499998e+005, max (m) = 5.093290e-005
   z-coordinate: min (m) = -3.500000e+005, max (m) = 3.500000e+005
Volume statistics:
   minimum volume (m3): 5.522024e-003
   maximum volume (m3): 1.100455e+013
     total volume (m3): 1.346829e+017
Face area statistics:
   minimum face area (m2): 8.720565e-003
   maximum face area (m2): 2.484231e+009
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking periodic boundaries.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Done.
  iter continuity x-velocity y-velocity z-velocity     energy        nut     time/iter
     1 1.0000e+00 1.9494e-05 1.6358e-05 1.5656e-05 7.3249e-04 1.4890e-01  0:28:03   99
temperature limited to 1.000000e+000 in 7 cells on zone 8 in domain 1
  temperature limited to 5.000000e+003 in 4 cells on zone 8 in domain 1
      2 1.0000e+00 1.9874e-01 2.5049e-01 1.9809e-01 9.2173e-03 1.3268e-02  0:27:07   98
temperature limited to 1.000000e+000 in 1872 cells on zone 8 in domain 1
  temperature limited to 5.000000e+003 in 6128 cells on zone 8 in domain 1
absolute pressure limited to 1.000000e+000 in 93 cells on zone 8  turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 1014 cells
     3 1.0000e+00 3.8391e-02 1.0722e-01 1.3003e-01 4.5968e+06 7.8557e-02  0:25:40   97
absolute pressure limited to 1.000000e+000 in 456632 cells on zone 8
Error: Floating point error: invalid number
Error Object: ()
发表于 2012-4-16 21:58:48 | 显示全部楼层
回复 1# ybyb1218 的帖子
检查一下你的边界条件设置是否合理 主要还是要把网格的过度调的好一点
 楼主| 发表于 2012-4-16 23:12:26 | 显示全部楼层
就是说,网格本身问题不大是吧
那么,我想请问一下。为什么同样的网格导入6.26和ansys12.0版本的fluent差这么多?而且我之前,拿二维网格做过试验。导入12.0的概率很小,而更多的是出现ACCESS问题。有时,不在ICEM里设边界条件有可能能导入。而6.26就没有这个问题。而三维网格则没有这个差别,都能顺利导入。计算结果没有对比。。。个人感觉还是老版本的6.26兼容性更好,对网格要求更低。
不建议用ANSYS自带的Fluent。当然,也许是我没有发现其中问题。
以上废话,我想问的是,这两个版本Fluent到底有啥大区别?
 楼主| 发表于 2012-4-17 22:28:00 | 显示全部楼层
回复 2# milaoshu 的帖子
问题已解决。已经能算了。多谢大家关心。我改了opration pressure,将reference pressure location,原来的(0,0,0)点怀疑不在计算域之内。
楼主,我按你说的 怎么还是不行呢? 您好记得您是怎么解决的不?  详情 回复 发表于 2015-11-24 14:53
发表于 2012-4-17 22:46:45 | 显示全部楼层
回复 3# ybyb1218 的帖子
我这里说一点自己的体会,6,3,26的版本相对来说兼容性是比较好,也许是时间长的原因吧,网格修复能力也是比较强的,虽然界面不是那么有好 但是习惯了感觉还是很不错,较新的版本确实界面好,而且增加了很多命令,但是有人也发现过新版本与6.3.26的计算结果的差异,具体是什么原因,也说不清楚,但是总体看来,差别不是很大,新版本增加了很多功能,而且很多命令也有改动,比如最新的13,14的版本中增加了DEFINE_TRANSIENT_MOTION这个宏,但是低版本就没有,总之呢 新的版本还有待大家的使用与评价。。。。个人见解
 楼主| 发表于 2012-4-18 08:47:56 | 显示全部楼层
回复 5# milaoshu 的帖子
但是像我上面所说的,新版本好多网格导不进去,会出现access 的问题。主要是二维的不好到进入,三维没有影响。曾经画过一个特别简单的二维网格,导不进12.0,却能导入6.26版本。
发表于 2012-4-18 08:56:31 | 显示全部楼层
回复 6# ybyb1218 的帖子
这个我倒没遇到过 我试的时候都可以
发表于 2015-11-24 14:53:12 | 显示全部楼层
ybyb1218 发表于 2012-4-17 22:28
问题已解决。已经能算了。多谢大家关心。我改了opration pressure,将reference pressure location,原来的 ...
发表于 2015-11-24 14:53:36 | 显示全部楼层
