查看: 2929|回复: 2
求教:有关用LBM模拟方腔内单颗粒固液两相流
发表于 2012-5-7 15:12:36 | 显示全部楼层 |阅读模式
一直在找LBM做方腔或者其他简单边界的,单颗粒或者少颗粒的三维流动模拟算例,但是在查阅大量文献后,发现用LBM做固液两相流方面的不是很多,现有的多是二维的模拟,三维方面的不多,而且都是多颗粒的模拟,一直没有找到单颗粒的简单边界的模拟算例,求相关算例或者文献!!
求教各位大牛,是因为用LBM研究方腔内单颗粒没有什么意义才没人玩儿的吗?另外大牛们有什么好的建议给一点吧!多谢啦!
发表于 2012-5-8 09:03:38 | 显示全部楼层
The LBE is a genuine multi-dimensional method, thus there is no inherent difference between 2D and 3D codes as far as programming is concerned. The significant difference is that 3D simulations take much longer time (orders of magnitude) thus people avoid it if they can.
Thus I do not see the reason why you have to insist on asking references for 3D simulations. You could read references on 2D simulations to learn the method and carry out the 3D simulations by yourself.
 楼主| 发表于 2012-5-8 09:18:08 | 显示全部楼层
回复 2# luo@odu.edu 的帖子
哦 这样啊 好吧 多谢您啦!
