查看: 7699|回复: 3
ansys13 安装许可证求助
发表于 2012-7-18 09:57:23 | 显示全部楼层 |阅读模式
我在win7 32位操作系统台式机上根据网上的安装程序很顺利完成了安装,可是运行ansys时却无法运行。我查看了Server ANSLIC_ADMIN Utility左下角显示:
ANSYS, Inc. License Manager status:
    Licensing Interconnect: running
    Licensing Interconnect Monitor: running
    FLEXlm: running
好像都很正常。但是运行fluent时却出现以下错误:
Failover feature ansys blademodeler specified in license preferences is not available.
Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file.
Feature:       fluent
Filename:      C:\PROGRA~1\ANSYSI~1\v130\fluent\licensetx86\..\license.dat
License path:  C:\PROGRA~1\ANSYSI~1\v130\fluent\licensetx86\..\license.dat
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
ANSYS LICENSE MANAGER ERROR:Failover feature 'ANSYS FLUENT Solver' specified in license preferences is not available.
Feature acfd_fluent_solver does not exist in the ANSYSLI pool.
System clock has been set back.
Feature:       acfd_fluent_solver
License path:  1055@wuanmin;
FLEXnet Licensing error:-88,309
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
查看了license内的计算机名和ID都是正确的,实在不知道是哪里出了问题。重装了操作系统再安装ansys还是这个问题。上网查了好几天,试了多种方法,依然无法解决。不知哪位高手能提点提点,万分感谢!
发表于 2012-7-18 13:54:13 | 显示全部楼层
你license是不是不在它提示的目录下,你在ANSYS, Inc. License Manager中 重新指定一下许可证试试。
发表于 2012-7-18 15:09:54 | 显示全部楼层
操作系统有问题?造成ansys的有些启动项没有启动,也就无法运行~~~
 楼主| 发表于 2012-7-19 13:47:11 | 显示全部楼层
license的目录是自动生成的,有这个licese.dat。不知道什么缘故。我在另外论坛上看到2楼发的ansys14版本的license,我下载后回去安装,也运行不了,一样的报错。有没有哪位高手帮我分析一下啊?
