查看: 4840|回复: 0
cfx计算错误,欢迎讨论共同进步
发表于 2012-9-20 09:45:09 | 显示全部楼层 |阅读模式
| SOLVING : Wall Scale                                               |
|       Equation       | Rate | RMS Res | Max Res |  Linear Solution |
Slave:   4
Slave:   4
Slave:   4  +--------------------------------------------------------------------+
Slave:   4  |                *** INSUFFICIENT MEMORY ALLOCATED ***               |
Slave:   4  |        |
Slave:   4  | ACTION REQUIRED : Increase the integer stack memory size.          |
Slave:   4  |        |
Slave:   4  | Details :                                                          |
Slave:   4  |   Requested space         :         296497 words                   |
Slave:   4  |   Current allocated space :       50994528 words                   |
Slave:   4  |   Current used space      :       50653062 words                   |
Slave:   4  |   Current free space      :         341466 words                   |
Slave:   4  |   Number of free areas    :              5                         |
Slave:   4  Fatal error generated in gKElSel
Slave:   4  Message :- FULL : Failed to make a data area for KElSel
Slave:   4  gKElSel called by :-  gKSelEl
Parallel run: Received message from slave
Slave partition :        4
Slave routine   : ErrAction
Master location : RCVBUF,MSGTAG=1032
Message label   : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Stopped in routine gKElSel                                         |
计算使用单机多核并行,但是老提示这个错误,核数少一点的话可以计算,多了有事计算一会就会出现这个问题,在cfx-pre里也调过expert parameter中的topology estimate factor为1.2,但是还是不行,在求解时将solver 的 memory allocation fact改为1.2也不行,这个到底是怎么回事啊,我的机子内存足够啊?求高手讨论,谢谢
