查看: 2734|回复: 0
请教:用fluent计算辐射出现的问题
发表于 2007-7-9 10:39:32 | 显示全部楼层 |阅读模式
请教:用fluent计算辐射出现的问题
用fluent计算辐射用所s2s模型计算角系数后读入时出现的问题:
Creating Surface Cluster...
Total Faces 35040, 35040 Surface Clusters created.
Writing "| gzip -cfv > F:\hhy\2222\h.s2s.gz"...
   35048 nodes.
    3744 quadrilateral wall faces, zone  4.
   16120 quadrilateral wall faces, zone  5.
    3744 quadrilateral wall faces, zone  6.
    3844 quadrilateral velocity-inlet faces, zone  7.
    3844 quadrilateral outflow faces, zone  8.
    3744 quadrilateral wall faces, zone  9.
The number of  radiating faces and radiating clusters are : 35040, 35040
Done.
   opening file F:\hhy\2222\h.s2s.gz
   using 1 processor(s)
FATAL ERROR: Premature EOF detected
command to execute: "D:\Fluent.Inc\utility\viewfac2.1\ntx86\vfs216.exe" F:\hhy\2222\h.s2s.gz
Reading "| gunzip -c \"F:\hhy\2222\h.s2s.gz\""...
You must read in a view factors file or disable S2S model before proceeding.
Error: Failed while reading view factor file.
Error Object: ()
Error: Error reading "| gunzip -c \"F:\hhy\2222\h.s2s.gz\"".
Error Object: #f
不知道怎么解决,请教各位,急盼!!!谢谢!
