查看: 3216|回复: 3
[求助]请教一个最小网格体积小于0的问题~谢谢~
发表于 2007-8-3 07:55:56 | 显示全部楼层 |阅读模式
[这个贴子最后由冰-蓝在 2007/08/03 07:56am 第 1 次编辑]
在处理3d模型的时候,在check时发现最小网格体积小于零,已经按如下步骤处理:
先initialize,激活adapt菜单下的一些选项,要用到的是iso-value,然后在grid下选cell volume,然后compute,会得到网格的体积范围,然后在iso min下填入最小负值,最大值填0,然后用mark,就可以得到一个iso的面,在旁边的manage菜单下的register会出现一个iso的面,用下面的display加上display grid命令,就可以很清楚的看到负体积在计算域的位置。
请接下来应该如何修改网格?
谢谢~
 楼主| 发表于 2007-8-3 07:58:44 | 显示全部楼层
具体问题如下:
Grid Check
Domain Extents:
   x-coordinate: min (m) = -3.000000e+01, max (m) = 3.000000e+01
   y-coordinate: min (m) = 0.000000e+00, max (m) = 8.000000e+01
   z-coordinate: min (m) = 0.000000e+00, max (m) = 1.000000e+01
Volume statistics:
WARNING: non-positive volumes exist.
   minimum volume (m3): -9.343046e-02
   maximum volume (m3): 4.942505e-01
     total volume (m3): 1.785395e+04
Face area statistics:
   minimum face area (m2): 2.998528e-06
   maximum face area (m2): 9.801429e-01
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
   Zone   3: 15075 right-handed,   445 left-handed
   Zone   7: 222869 right-handed,  1771 left-handed
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking periodic boundaries.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Done.
WARNING: Grid check failed.
发表于 2007-8-3 16:45:33 | 显示全部楼层
remesh it in the meshing software.
发表于 2025-8-2 11:25:58 | 显示全部楼层
冰-蓝 发表于 2007-8-3 07:58
具体问题如下:
Grid Check
Domain Extents:
同问,我的研究对象是风力机叶片,Mark叶片负体积的位置,叶片网格质量一直划分不好,求助各位前辈。
