查看: 2388|回复: 6
求助,请帮我看看什么问题!
发表于 2013-3-7 08:48:36 | 显示全部楼层 |阅读模式
Domain Extents:
   x-coordinate: min (m) = -5.000000e+001, max (m) = 5.000000e+001
   y-coordinate: min (m) = -5.000000e+001, max (m) = 5.000000e+001
   z-coordinate: min (m) = -2.000000e+001, max (m) = 2.000000e+001
Volume statistics:
   minimum volume (m3): 3.538547e-001
   maximum volume (m3): 5.262538e-001
     total volume (m3): 4.000000e+005
Face area statistics:
   minimum face area (m2): 4.444444e-001
   maximum face area (m2): 6.632644e-001
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking cell connectivity.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
Checking face node order.
Checking closed cells.
Checking contact points.
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking wall distance.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Done.
WARNING: Mesh check failed.
发表于 2013-3-7 09:35:57 | 显示全部楼层
回复 1# Please_Help 的帖子
把你的mesh图片贴下
 楼主| 发表于 2013-3-7 10:25:34 | 显示全部楼层
 楼主| 发表于 2013-3-7 10:26:24 | 显示全部楼层
原帖由 milaoshu 于 2013-3-7 09:35 发表
把你的mesh图片贴下
麻烦帮我看一看啊
发表于 2013-3-7 10:42:23 | 显示全部楼层
回复 4# Please_Help 的帖子
你这个中间好像有个交界面 在fluent里创建interface 然后在check
 楼主| 发表于 2013-3-7 15:07:21 | 显示全部楼层
[quote]原帖由 milaoshu 于 2013-3-7 10:42 发表
你这个中间好像有个交界面 在fluent里创建interface 然后在check [/quot
谢谢,我先试一下!
发表于 2013-3-7 15:13:32 | 显示全部楼层
回复 6# Please_Help 的帖子
具体做法是在网格划分的时候指定每个面一个名称,类型都是interface,然后在fluent里设置他们是一对
