查看: 2359|回复: 0
一个UDF并行报错
发表于 2013-3-11 19:41:46 | 显示全部楼层 |阅读模式
一个UDF,在单核情况下可以正确编译并计算。
但将UDF作并行修改处理后,再作并行计算时,初始化便报如下错误,请有经验的前辈指点一二啊,什么情况会导致如下报错发生,感激不尽!!!
999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
The Parallel FLUENT process could not be started.
