查看: 2051|回复: 0
The row type
发表于 2013-4-10 09:59:19 | 显示全部楼层 |阅读模式
在autogrid的用户手册中有这么一句话"The row type is used to specify the row location in case of bypass configuration. Four types, identifiedby the keyword NORMAL, ON_NOZZLE, IN_BYPASS and DOWN_BYPASS, are respectivelyused to locate the row before the nozzle (inlet fan), on the nozzle (arm), in the bypass and in the compressor."对其中的in case of bypass configuration., locate the row before the nozzle (inlet fan)不太明白,哪位大侠能指点一下,谢了
