查看: 5857|回复: 1
CEASIOM各模块运行问题集合
发表于 2013-5-10 20:49:45 | 显示全部楼层 |阅读模式
各位,前段时间我在休假,回来很高兴看到大家都在尝试运行CEASIOM。这个帖子供大家把运行中遇到的各种问题以及报错集合起来,我会一一解答。
[ 本帖最后由 张萌萌 于 2013-5-10 14:26 编辑 ]
发表于 2014-1-19 20:27:29 | 显示全部楼层
回复 1# 张萌萌 的帖子
是不是matlab版本必须是2008的版本,用了2013b,运行,照着视频tcr-c运行,错误一大堆
而且刚开始这是开源项目,其实是freeware,matlab的p代码
模块acbuilder,不能启动
Starting AcBuilder (this can take a while) ...
Warning: Possible deprecated use of set on a Java object with an HG Property 'ActionPerformedCallback'.
> In D:\Users\Administrator\Documents\MATLAB\ceaSIOM100-v3.0\Geometry\AcBuilder\acbuilder.p>acbuilder at 41
  In D:\Users\Administrator\Documents\MATLAB\ceaSIOM100-v3.0\CEASIOM.p>pb1_call at 346
Exception in thread "AWT-EventQueue-0" java.lang.VerifyError: class com.sun.opengl.impl.GLContextImpl overrides final method isCreated.()Z
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClass(Unknown Source)
        at java.security.SecureClassLoader.defineClass(Unknown Source)
        at java.net.URLClassLoader.defineClass(Unknown Source)
        at java.net.URLClassLoader.access$100(Unknown Source)
        at java.net.URLClassLoader$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(Unknown Source)
        at com.mathworks.jmi.CustomURLClassLoader.findClass(ClassLoaderManager.java:760)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at GLViewer.<init>(GLViewer.java:34)
        at AcBuilder.run(AcBuilder.java:120)
        at java.awt.event.InvocationEvent.dispatch(Unknown Source)
        at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.access$200(Unknown Source)
        at java.awt.EventQueue$3.run(Unknown Source)
        at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
[ 本帖最后由 alljoyland 于 2014-1-19 20:33 编辑 ]
