查看: 3016|回复: 1
win8 64位安装ansys14问题
发表于 2014-2-5 01:08:08 | 显示全部楼层 |阅读模式
求高手帮忙解答一下。都快折腾死了。
问题描述:
1,原来装了ansys14.0,但是因为要用并行计算,开始那个intel MPI没设置好,后面嫌麻烦就卸载了14.0,装14.5,但是发现14.5怎么都装不好,又回来装14.0
2,按照网上的安装流程装了14.0后 workbench 能够正常打开,但是fluent打不开总是提示没有liscense的问题
3,软件提示的详细问题如下:
Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature:       fluent
Filename:      C:\PROGRA~1\ANSYSI~1\v140\fluent\license\win64\..\license.dat
License path:  C:\PROGRA~1\ANSYSI~1\v140\fluent\license\win64\..\license.dat
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
ANSYS LICENSE MANAGER ERROR:Failover feature 'ANSYS FLUENT Solver' specified in license preferences is not available.
Request name acfd_fluent_solver does not exist in the licensing pool.
System clock has been set back.
Feature:       acfd_fluent_solver
License path:  1055@Lenovo-PC;
FLEXnet Licensing error:-88,309
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
真心求高手解答下这个问题怎么处理??急死了都。
发表于 2014-2-8 08:24:10 | 显示全部楼层
就是license没有装好。
