查看: 4951|回复: 13
柱塞泵的仿真求解
发表于 2014-2-10 08:24:36 | 显示全部楼层 |阅读模式
我正在做柱塞泵的仿真,具体情况是这样的:9个斜柱塞的盘配流式柱塞泵,前处理已经完成,但是在动网格的UDF编译这里我有点迷惑,就是柱塞的运动。针对柱塞运动速度的公式的编写,我不知道该从哪个方面思考,各位老师能不能帮我回答一下啊?给我提供个大致的思考方向就可以。谢谢各位老师了
发表于 2014-2-10 12:13:00 | 显示全部楼层
回复 1# 梅梅 的帖子
用神马工具在做?FLUENT?
 楼主| 发表于 2014-2-10 12:47:16 | 显示全部楼层
回复 2# lihua_0629 的帖子
是啊,能不能交流一下经验啊?
发表于 2014-2-10 18:16:07 | 显示全部楼层
用 CG_motion给定运动规律 转动加平动 运动的活塞底面用层变
 楼主| 发表于 2014-2-11 07:52:34 | 显示全部楼层
回复 4# zoeywang 的帖子
#include "udf.h"
#include "dynamesh_tools.h"
#define BMODULUS 1.7e9
#define R 37.65
#define bat 13.0
#define sat 5.0
#define N 9.0
#define n 1500.0
DEFINE_CG_MOTION(piston1, dt, vel1, omega, time, dtime)
  real dfai1, w, vp1;
   dfai1 =  2*3.14159265*0.5/9.0;
   w = 2*3.14159265*n/60;
   vp1=R*w*sin(w*time+dfai1)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
    /* set x-component of velocity */
   vel1[0] = -vp1*sin(sat*3.14159265/180)*sin(w*time+dfai1);
    /* set y-component of velocity */
   vel1[1] = -vp1*sin(sat*3.14159265/180)*cos(w*time+dfai1);
    /* set z-component of velocity */
   vel1[2] = vp1*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston2, dt, vel2, omega, time, dtime)
  real dfai2, w, vp2;
   dfai2 = 2*3.14159265*1.5/9.0;
   vp2=R*w*sin(w*time+dfai2)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel2[0] = -vp2*sin(sat*3.14159265/180)*sin(w*time+dfai2);
   vel2[1] = -vp2*sin(sat*3.14159265/180)*cos(w*time+dfai2);
   vel2[2] = vp2*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston3, dt, vel3, omega, time, dtime)
  real dfai3, w, vp3;
   dfai3 = 2*3.14159265*2.5/9.0;
   vp3=R*w*sin(w*time+dfai3)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel3[0] = -vp3*sin(sat*3.14159265/180)*sin(w*time+dfai3);
   vel3[1] = -vp3*sin(sat*3.14159265/180)*cos(w*time+dfai3);
   vel3[2] = vp3*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston4, dt, vel4, omega, time, dtime)
  real dfai4, w, vp4;
   dfai4 = 2*3.14159265*3.5/9.0;
   vp4=R*w*sin(w*time+dfai4)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel4[0] = -vp4*sin(sat*3.14159265/180)*sin(w*time+dfai4);
   vel4[1] = -vp4*sin(sat*3.14159265/180)*cos(w*time+dfai4);
   vel4[2] = vp4*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston5, dt, vel5, omega, time, dtime)
  real dfai5, w, vp5;
   dfai5 = 2*3.14159265*4.5/9.0;
   vp5=R*w*sin(w*time+dfai5)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel5[0] = -vp5*sin(sat*3.14159265/180)*sin(w*time+dfai5);
   vel5[1] = -vp5*sin(sat*3.14159265/180)*cos(w*time+dfai5);
   vel5[2] = vp5*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston6, dt, vel6, omega, time, dtime)
  real dfai6, w, vp6;
   dfai6 = 2*3.14159265*5.5/9.0;
   vp6=R*w*sin(w*time+dfai6)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel6[0] = -vp6*sin(sat*3.14159265/180)*sin(w*time+dfai6);
   vel6[1] = -vp6*sin(sat*3.14159265/180)*cos(w*time+dfai6);
   vel6[2] = vp6*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston7, dt, vel7, omega, time, dtime)
  real dfai7, w, vp7;
   dfai7 = 2*3.14159265*6.5/9.0;
    vp7=R*w*sin(w*time+dfai7)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel7[0] = -vp7*sin(sat*3.14159265/180)*sin(w*time+dfai7);
   vel7[1] = -vp7*sin(sat*3.14159265/180)*cos(w*time+dfai7);
   vel7[2] = vp7*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston8, dt, vel8, omega, time, dtime)
  real dfai8, w, vp8;
   dfai8 = 2*3.14159265*7.5/9.0;
   vp8=R*w*sin(w*time+dfai8)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(cos(sat*3.14159265/180)*(1-cos(w*time+dfai8)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel8[0] = -vp8*sin(sat*3.14159265/180)*sin(w*time+dfai8);
   vel8[1] = -vp8*sin(sat*3.14159265/180)*cos(w*time+dfai8);
   vel8[2] = vp8*cos(sat*3.14159265/180);
DEFINE_CG_MOTION(piston9, dt, vel9, omega, time, dtime)
  real dfai9, w, vp9;
   dfai9 = 2*3.14159265*8.5/9.0;
   vp9=R*w*sin(w*time+dfai9)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/(cos(sat*3.14159265/180)*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))*(1+cos(sat*3.14159265/180)*tan(bat*3.14159265/180)*tan(sat*3.14159265/180))/1000;
   vel9[0] = -vp9*sin(sat*3.14159265/180)*sin(w*time+dfai9);
   vel9[1] = -vp9*sin(sat*3.14159265/180)*cos(w*time+dfai9);
   vel9[2] = vp9*cos(sat*3.14159265/180);
我要仿真的是写柱塞的一个柱塞泵,没个柱塞我都建立了局部坐标,所以在全局坐标中需要转化,您看我编译的有问题吗?还有,您说的运动的底面用层变是怎么设置呢?在Gambit中设置边界条件的时候在动网格这里我该怎么设置呢?将运动柱塞的底面设置为Wall吗?
发表于 2014-2-12 20:03:51 | 显示全部楼层
我也在做这个,可以交流下
我现在也在做柱塞泵的模拟,方便加个qq或者微信吗,想请教您一些问题  详情 回复 发表于 2020-4-17 11:33
 楼主| 发表于 2014-2-13 07:51:49 | 显示全部楼层
回复 6# france 的帖子
你的QQ是多少啊?我加你啊?
我现在也在做柱塞泵的模拟,方便加个qq或者微信吗,想请教您一些问题  详情 回复 发表于 2020-4-17 11:10
发表于 2014-2-27 11:26:58 | 显示全部楼层
我也在做这个 加个QQ 79021008
发表于 2014-10-17 14:50:56 | 显示全部楼层
我最近也在做这个,感觉你柱塞运动的UDF写得太复杂了,不用局部坐标应该也可以,不知能否交流下?
发表于 2019-4-16 13:16:39 | 显示全部楼层
大家好,我也做这方面的研究,能否交流一下1528877172,谢谢
发表于 2019-4-16 13:17:41 | 显示全部楼层
发表于 2020-4-17 11:10:05 | 显示全部楼层
梅梅 发表于 2014-2-13 07:51
你的QQ是多少啊?我加你啊?
发表于 2020-4-17 11:33:08 | 显示全部楼层
france 发表于 2014-2-12 20:03
我也在做这个,可以交流下
发表于 2020-4-17 11:33:31 | 显示全部楼层
