查看: 3345|回复: 7
求助两相流udf问题
发表于 2014-3-5 15:52:42 | 显示全部楼层 |阅读模式
请各位大神帮我看看这个udf,计算不了几步就发散
#include "udf.h"
#include "sg_mphase.h"
DEFINE_SOURCE(liq_src,c,pri_th,dS,eqn)
Thread *mix_th,*sec_th;
real m_dot_l;
real stc;
real fv;
real pres_vap;
real pres_sat;
real pres_turb;
mix_th=THREAD_SUPER_THREAD(pri_th);
sec_th=THREAD_SUB_THREAD(mix_th,1);
fv=C_VOF(c,sec_th)*C_R(c,sec_th)/(C_VOF(c,sec_th)*C_R(c,sec_th)+C_VOF(c,pri_th)*C_R(c,pri_th));
stc=5.98633e-7*C_T(c,mix_th)*C_T(c,mix_th)-3.21398e-4*C_T(c,mix_th)+0.03015;
pres_sat=0.04782*C_T(c,mix_th)*C_T(c,mix_th)*C_T(c,mix_th)*C_T(c,mix_th)-4.33987*C_T(c,mix_th)*C_T(c,mix_th)*C_T(c,mix_th)-172.30441*C_T(c,mix_th)*C_T(c,mix_th)+27971.53714*C_T(c,mix_th)-734733.4355;
pres_turb=0.39*C_R(c,mix_th)*C_K(c,mix_th);
pres_vap=pres_sat+0.5*pres_turb;
if(C_P(c,mix_th)<=pres_vap)
m_dot_l=-0.02*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,sec_th)*sqrt((2*(pres_vap-C_P(c,mix_th)))/(3*C_R(c,pri_th)))*(1-fv);
dS[eqn]=-0.02*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,sec_th)*sqrt((2*(pres_vap-C_P(c,mix_th)))/(3*C_R(c,pri_th)));
else
m_dot_l=0.01*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,pri_th)*sqrt((2*(C_P(c,mix_th)-pres_vap))/(3*C_R(c,pri_th)))*fv;
dS[eqn]=0;
return m_dot_l;
DEFINE_SOURCE(vap_src,c,sec_th,dS,eqn)
Thread *mix_th,*pri_th;
real m_dot_v;
real stc;
real fv;
real pres_vap;
real pres_sat;
real pres_turb;
mix_th=THREAD_SUPER_THREAD(sec_th);
pri_th=THREAD_SUB_THREAD(mix_th,0);
m_dot_v=0.02*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,sec_th)*sqrt((2*(pres_vap-C_P(c,mix_th)))/(3*C_R(c,pri_th)))*(1-fv);
dS[eqn]=0;
else
m_dot_v=-0.01*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,pri_th)*sqrt((2*(C_P(c,mix_th)-pres_vap))/(3*C_R(c,pri_th)))*fv;
dS[eqn]=-0.01*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,pri_th)*sqrt((2*(C_P(c,mix_th)-pres_vap))/(3*C_R(c,pri_th)));
return m_dot_v;
DEFINE_SOURCE(enrg_src,c,mix_th,dS,eqn)
Thread *pri_th,*sec_th;
real m_dot;
real hc;
real source;
real stc;
real fv;
real pres_vap;
real pres_sat;
real pres_turb;
hc=-3.01379e-4*C_T(c,mix_th)*C_T(c,mix_th)*C_T(c,mix_th)+0.05766*C_T(c,mix_th)*C_T(c,mix_th)-4.80036*C_T(c,mix_th)+364.96837;
m_dot=-0.02*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,sec_th)*sqrt((2*(pres_vap-C_P(c,mix_th)))/(3*C_R(c,pri_th)))*(1-fv);
source=m_dot*hc;
dS[eqn]=0;
else
m_dot=0.01*sqrt(C_K(c,mix_th))/stc*C_R(c,pri_th)*C_R(c,pri_th)*sqrt((2*(C_P(c,mix_th)-pres_vap))/(3*C_R(c,pri_th)))*fv;
source=m_dot*hc;
dS[eqn]=0;
return source;
发表于 2014-4-1 16:42:06 | 显示全部楼层
请问你的问题解决了吗?我的也有类似问题、、、
 楼主| 发表于 2014-4-2 09:27:58 | 显示全部楼层
回复 2# langlovezhuzhu 的帖子
还没有
发表于 2014-4-2 12:53:30 | 显示全部楼层
为啥满世界都是这个烂模型,试想如下程序
if(a<=0) a=1
if(a>=1) a=0;
那a的值就会在0和1之间来回蹦,刚要到0又被你改成1,刚到1又被你改成0,残差还能稳定下降吗?
 楼主| 发表于 2014-4-3 09:42:11 | 显示全部楼层
回复 4# gearboy 的帖子
您好。请问该怎么改呢?我的判定条件是压力,根据压力的关系确定质量表达式,即
if(p<pv) m=....;if(p>pv) m=....跟楼主说的if(a<=0) a=1 if(a>=1) a=0一样吗?
发表于 2014-4-3 14:41:36 | 显示全部楼层
差不多类似吧,试想p>pv时,假设m=1,p<pv时m=-1,那么当p>pv时你的源项就是m=1,必然引起系统变化,残差上升,然后一步一步迭代,好不容易下降稳定下来,这时候又变成p<pv了,系统必然又不稳定,残差再次上升。然后又开始迭代逐渐稳定,刚稳定又出现p>pv。所以整个过程残差会上下跳。除非在p=pv的地方,你的两个m的计算结果是相同的,也就是满足连续性。可惜,我看你的两个m的表达式计算结果是不同的。
[ 本帖最后由 gearboy 于 2014-4-3 06:42 编辑 ]
发表于 2014-5-18 10:09:47 | 显示全部楼层
楼主,你的问题解决了吗?我现在也碰到这个问题,求解答,谢谢
 楼主| 发表于 2014-5-19 14:21:06 | 显示全部楼层
回复 7# sanhuzb 的帖子
没有解决呢
