查看: 2378|回复: 0
UDF调试出现一些问题,求帮助!
发表于 2014-3-11 21:37:24 | 显示全部楼层 |阅读模式
模拟一个弹簧壁面的运动,compiled的时候出现如下错误:
> Copied D:\VS2010\VC\spring\cg_motion.c to libudf\src
Creating user_nt.udf file for 3d_host ...
(system "copy "D:\ANSYSI~1\v145\fluent"\fluent14.5.0\src\makefile_nt.udf "libudf\win64\3d_host\makefile" ")
已复制         1 个文件。
(chdir "libudf")()
(chdir "win64\3d_host")()
# Generating ud_io1.h
cg_motion.c
# Generating udf_names.c because of makefile cg_motion.obj
udf_names.c
udf_names.c(7) : error C2059: 语法错误:“}”
udf_names.c(8) : warning C4034: sizeof 返回 0
Creating user_nt.udf file for 3d_node ...
(system "copy "D:\ANSYSI~1\v145\fluent"\fluent14.5.0\src\makefile_nt.udf "libudf\win64\3d_node\makefile" ")
已复制         1 个文件。
(chdir "libudf")()
(chdir "win64\3d_node")()
cg_motion.c
udf_names.c
UDF程序如下
#include "udf.h"
static real v_prev = 0.0;
static real f = 120.211498;
static real k = 53.0022;
static real vector[3] = {0,1,0};
DEFINE_CG_MOTION(spring,dt,vel,omega,time,dtime)
    Thread *t;
    face_t f;
    real NV_VEC(A);
    real force, dv;
    real x[ND_ND];
    real y = 0.0;
    real z = 0.0;
    /* reset velocities */
    NV_S(vel, =, 0.0);
    NV_S(omega, =, 0.0);
    if (!Data_Valid_P())
      return;
    /* get the thread pointer for which this motion is defined */
    t = DT_THREAD(dt);
    /* compute pressure force on body by looping through all faces */
    force = 0.0;
    begin_f_loop(f,t)
         F_AREA(A,f,t);
         force += F_P(f,t) * NV_DOT(A,vector);
         F_CENTROID(x,f,t);
         if (x[1] > z ) z = x[1];
    end_f_loop(f,t)
    /* compute change in velocity, that is, dv = F * dt / mass  velocity update using explicit Euler formula */
    y = 0.0161 - z;
    dv = dtime * ( force + y * k + f ) / 0.0025;
    v_prev += dv;
    Message ("time = %f, y_vel = %f, force = %f\n", time, v_prev,
                force);
    /* set y-component of velocity */
    vel[1] = v_prev;
