查看: 3365|回复: 5
求各位大侠建议:适体坐标系上计算圆柱绕流问题
发表于 2014-5-16 22:27:01 | 显示全部楼层 |阅读模式
如题,预在适体坐标系上求解二维圆柱绕流问题,现通过求解微分方程得到物理平面的网格,但是网格效果不是很理想,求各位大侠的宝贵建议!
发表于 2014-5-18 17:25:57 | 显示全部楼层
圆柱绕流,柱坐标体系就是一个很好的适体坐标系啊,难道我的理解有问题?
我也不明白这个例子为什么要用求解微分方程生成网格。。。
发表于 2014-5-18 20:11:37 | 显示全部楼层
想搞个H网格?
发表于 2014-5-25 06:18:56 | 显示全部楼层
你求解的是什么微分方程?
原帖由 dream661 于 2014-5-16 22:27 发表
 楼主| 发表于 2014-6-24 09:56:20 | 显示全部楼层
回复 4# flowinflow 的帖子
解的泊松方程
发表于 2014-6-24 18:09:33 | 显示全部楼层
I guess you wanted to use the iso lines of your poisson equation solution
as the CFD mesh. I tried to do this 6 or 7 years ago... Not worth your time.
(1) you can use cylindrical coordinate
(2) computing the iso lines after the poisson eqn. is solved is still not trivial.
(3) in the end, your 'conformal grid' is numerical, not analytic, and therefore
is to some extend useless, because you'll need to compute the grid transformation
matrix numerically, which introduces extra error
a conformal grid is useful only when you have the analytic mapping function
原帖由 dream661 于 2014-6-24 09:56 发表
解的泊松方程
