查看: 8568|回复: 0
ERROR #001100279 has occurred in subroutine ErrAction.
发表于 2014-7-4 14:08:52 | 显示全部楼层 |阅读模式
做FSI分析 CFX出现这个错误 该怎么解决啊? +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction.             | | Message:                                                           | | CFX encountered the error: Read.  Fatal error occurred when reque- | | sting Total Mesh Displacement for Interface_wing.                  | |        | |        | |        | |        | +--------------------------------------------------------------------+  +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction.             | | Message:                                                           | | cplg_SendCommand failed to send the command: ERROR -- CFX encount- | | ered the error: Read.  Fatal error occurred when requesting Total  | | Mesh Displacement for Interface_wing.                              | |        | |        | |        | +--------------------------------------------------------------------+  +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction.             | | Message:                                                           | | Stopped in routine cplg_SendCommand                                | |        | |        | |        | |        | |        | +--------------------------------------------------------------------+ ------------------------------------------------------------------------------------------------- *** ERROR ***                           CP =     455.828   TIME= 05:33:07 One or more elements have become highly distorted.  Excessive            distortion of elements is usually a symptom indicating the need for      corrective action elsewhere.  Try ramping the load up instead of step    applying the load (KBC,1).  You may need to improve your mesh to         obtain elements with better aspect ratios.  Also consider the behavior   of materials, contact pairs, and/or constraint equations.  If this       message appears in the first iteration of first substep, be sure to      run shape checking of elements.
