查看: 3658|回复: 3
跪求!圆柱运动时格点处理!!
发表于 2014-10-9 18:48:29 | 显示全部楼层 |阅读模式
求问,在圆柱绕流时,圆柱运动时,有新流体节点产生,而有的流体节点到了圆柱内部,新的流体节点怎么处理??PS:我使用统一边界处理来处理圆柱边界的
 楼主| 发表于 2014-10-11 08:30:32 | 显示全部楼层
回复 1# degenerate 的帖子
自己给自己回一下!大神们,求出手啊
发表于 2014-10-24 20:59:42 | 显示全部楼层
There are several approaches to deal with this issue, none of them is perfect, of course. Have you read some of the previous papers?
-- LS Luo
 楼主| 发表于 2014-12-1 09:32:02 | 显示全部楼层
luo@odu.edu 发表于 2014-10-24 20:59
There are several approaches to deal with this issue, none of them is perfect, of course. Have you r ...
Sorry to reply you message so late.  I have read some papers on dealing with the new lattice which changes from the solid lattice into fluid lattice. But all of them are interpolation methods(e.g. Bouzidi; Lallemand; Zhaoli Guo).  I think these approaches will have an effect on the non-slip boundary conditions.
