查看: 3641|回复: 3
LBM模拟涡激振动时振动方程如何处理?
发表于 2014-10-27 21:10:36 | 显示全部楼层 |阅读模式
请问各位大神们,图片中的振动方程的Y等参数怎么换算成格子单位?如何求解,右边项需要化成正余弦的形式么?
发表于 2014-10-30 21:38:40 | 显示全部楼层
This is a 2nd-order ordinary differential equation (ODE) with constant coefficients, right? If so, why use the LBE to solve it?
-- LSL
 楼主| 发表于 2014-12-4 16:46:24 | 显示全部楼层
luo@odu.edu 发表于 2014-10-30 21:38
This is a 2nd-order ordinary differential equation (ODE) with constant coefficients, right? If so, w ...
您好,因为每次迭代后升力系数都在变化,而升力系数的变化是正弦变化关系,在求解的时候,只需要将右边的当做常数求解么?
发表于 2014-12-12 08:35:36 | 显示全部楼层
You need to provide a complete description of the problem.
