查看: 12396|回复: 0
the fluent was crashed and disapeared when run UDF
发表于 2015-1-15 10:21:29 | 显示全部楼层 |阅读模式
#include"udf.h"
real vn=0.0;
FILE * fp;
DEFINE_CG_MOTION(dynamic_cylinder,dt,vel,omega,tim e,dtime)
vn=5*sin(5*time);
vel[1]=vn;
omega[2]=2;
DEFINE_EXECUTE_AT_END(execute_at_end)
int n;
fp=fopen("D:\\temp\\shiyan","a_v");
fprintf(fp,"% E\n",vn);
fclose(fp);
i want use the UDF above write a file to record the velocity data, but two problems puzzle me:
1 i have sucessfully compiled the UDF, but when i ran caculation the fluent was crashed, disapeared in the screen.(when i remove the macro DEFINE_EXECUTE_AT_END, the UDF run well)
2 i want the body move in vertical direction and rotate aroud its center simutaneously, but the coordinate of the body center is not (0,0), how should i do ?(2D caculation)
Could anyone can help me? many thanks in advance...
