查看: 2050|回复: 7
从水池底部喷射高速度气体的模拟
发表于 2003-8-15 20:10:27 | 显示全部楼层 |阅读模式
请教大虾,有谁用FLUENT模拟从一个高约0。3米的水池底部喷吹气体的二相流的问题。喷嘴直径大约2毫米,出口速度200/s.
发表于 2003-8-18 15:40:30 | 显示全部楼层
从水池底部喷射高速度气体的模拟
俺也有同样的问题,谁能帮帮俺,俺先谢谢了!
发表于 2003-8-18 20:35:49 | 显示全部楼层
从水池底部喷射高速度气体的模拟
这个问题实际上用VOF和MIXTURE两种模型都可以算,但算出来正不正确却很难讲.
 楼主| 发表于 2003-8-20 21:28:25 | 显示全部楼层
从水池底部喷射高速度气体的模拟
yes, I agree with you. As a matter of fact, I have tried these two method and compared with the water model. Ii is hard to say the calculated results is correct.
 楼主| 发表于 2003-8-20 21:30:54 | 显示全部楼层
从水池底部喷射高速度气体的模拟
this is one of my results using VOF model.  Blowing argon from bottom of AOD. Three phase, liquid steel, argon and liquid slag is included.
发表于 2003-8-28 16:25:54 | 显示全部楼层
从水池底部喷射高速度气体的模拟
In the documentation of fluent, it is introduced that VOF model is more appropriate to big bubbles in liquid.  But to me, the result is good enough. I am simmulate the flow field in a bubble column. My calibration can not be converged. Fluent tells me the Error in AMG solver: x-momentum. I cann't find what's the wrong. Dear Dr. cfc-fluent, do you know the reason!
发表于 2003-8-28 16:56:40 | 显示全部楼层
从水池底部喷射高速度气体的模拟
我用fluent计算鼓泡塔,但计算总不收敛。提示信息:Diconverge in AMG solver: x-momentum.
网格:2D网格,轴对称;
Solver: segreted+steady
multiphase:Euler (water+air)
Viscous: k-epsilon
Discrete phase:default
Operation conditions: 101325Pa + gavity
Boundary conditions: 空气入口:velocity-inlet(air:0.5m/s); 自由面:pressure-outlet(back flow是瞎设置的).
清各位高手支招!
发表于 2010-2-2 14:53:11 | 显示全部楼层
很高深吗 很厉害啊
