查看: 5922|回复: 5
CFX流固耦合问题——螺旋桨
发表于 2016-3-21 09:57:23 | 显示全部楼层 |阅读模式
我在计算流固耦合的时候,开始计算都顺利,在计算了200步以后,出现以下错误:
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS.         |
| The connection between this CFX process and an external process    |
| has died unexpectedly.  The following error was received:          |
|   External process  : ANSYS                                        |
|   Error experienced : Read                                         |
| ** This error is fatal:  Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX    |
| and external processes to determine the cause of the error.        |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
同时,计算收敛图为:
求教各位大神,这里是出现了什么问题啊!!
发表于 2017-7-4 10:10:40 | 显示全部楼层
你好,请问你的问题解决了吗?我也遇到了同样的问题,希望大神不吝赐教
发表于 2017-9-4 15:25:55 | 显示全部楼层
得看看具体的设置参数
发表于 2017-9-5 15:05:04 | 显示全部楼层
感觉你的残差曲线图奇怪啊
发表于 2017-9-5 21:11:00 | 显示全部楼层
我他妈的知道你的错误在哪里了,,因为我刚刚也他妈的遇到了,你可能是把介质设置错了,或者忘了设置了,你检查一下你的流体介质
发表于 2017-9-9 16:28:58 | 显示全部楼层
怎么画结构网格啊   我都快要疯了
