查看: 2865|回复: 1
牛人请看看为什么,fluent无法读取mesh文件
发表于 2006-4-26 22:49:41 | 显示全部楼层 |阅读模式
> Reading "| utility fl42seg C:\Documents and Settings\dlx\yiti.msh"...
Convert a Fluent/V4 case file and optional data file or preBFC grid file to Fluent/UNS 4.
Usage: fl42uns4 [-d datafile] [infile [outfile]]
-d datafile Read and write a data file in addition to the case file.
infileInput case filename. Default is standard input.
outfileOutput filename. Default is standard output.
Building...
     grid,
Error: Null Domain Pointer
Error Object: ()
发表于 2006-10-22 08:32:28 | 显示全部楼层
我也遇到了同样的问题,只是没法解决,哪位好心人救救我?
